1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: CSS Boy and Signed/Unsigned Int Issue
To: <[email protected]>, <[email protected]>
Date: Mon, 13 Apr 2015 14:08:34 +0000
Hi Matt,
Thanks for this - this seems to solve the problem properly and I didn't notice any negative performance issues in what we are doing with it.
Ian
Sent: 13 April 2015 08:50
To: Bush, Ian (Tessella,RAL,CLF); [email protected]
Hi Ian,
At Diamond we wanted this functionality so we made a patch which converts the data (on the UI thread) for the intensity graph. As this may negatively affect the performance, and doesn't use the new Java 8 unsigned type for the conversion, it isn't merged into CSS. You can see the discussion and pull request here:
https://github.com/ControlSystemStudio/cs-studio/issues/823
Matt
From: [email protected] [[email protected]] on behalf of [email protected] [[email protected]]
Sent: 08 April 2015 12:01
To: [email protected]
Subject: CSS Boy and Signed/Unsigned Int Issue
Hi all,
I am having a problem with a camera that uses unsigned 8-bit integers for its values, which get interpreted as -127 --> 128 instead of 0 --> 255 in CSS BOY.
I saw on a previous discussion there was a suggested workaround (http://www.aps.anl.gov/epics/tech-talk/2014/msg00510.php), but this does not work for me due to some auto-normalisation scripts we are using, and this would also prevent choosing color maps.
I was just wondering if anyone had found a better solution to the issue? Trying to use a Python script to correct the values seems to be extremely slow.
Ian
CSS Boy and Signed/Unsigned Int Issue ian.bush
RE: CSS Boy and Signed/Unsigned Int Issue matthew.furseman
Prev: Re: StreamDevice reading waveforms Dirk Zimoch
Next: Re: StreamDevice reading waveforms Anthony Pietryla
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: CSS Boy and Signed/Unsigned Int Issue matthew.furseman
Next: Analog output record (softChannel): How to easily prevent VAL field's clipping within limits Heinz Junkes
