1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: StreamDevice reading waveforms
To: Dirk Zimoch <[email protected]>
Cc: [email protected]
Date: Mon, 13 Apr 2015 09:15:41 -0500
Dirk,
I tried a form of that where the first (horizontal) record used I/O intr and forward linked to the vertical record. I would get one value in each waveform then I would receive the error about “surplus input”.
Tony
On Apr 13, 2015, at 9:05 AM, Dirk Zimoch <[email protected]> wrote:
Hello Anthony,
In principle you can also use "I/O Intr" for the two longin records. They should trigger for each line. But I cannot guarantee this.
record (longin, "$(P)$(R)TBT_Horizontal_tmp")
 field (DTYP, "stream")
 field (INP,  "@spark.proto getTBT_X $(PORT)")
 field (SCAN, "I/O Intr")
 field (FNLK, "$(P)$(R)TBT_Horizontal")
Similar for vertical.
Terminator = "\n";
# only trigger reading
getTBT_XY {
 out "TBT_XY 3";
# processes the I/O Intr records once for each input line
getTBT_X_line {
   in "%i %*i";
getTBT_Y_line {
   in "%*i %i";
Unfortunately EPICS isn't very good at multi-dimensional arrays.
Dirk
On 13.04.2015 14:59, Anthony Pietryla wrote:
Hi Dirk,
Thank you for your reply. Unfortunately, there are many more than three
rows to read, up to 256k samples/channel. I used a value of three for my
debugging.
One suggestion I received was to read everything into one huge array and
use an asub record to parse the values.
Tony
On Apr 13, 2015, at 3:54 AM, Dirk Zimoch <[email protected]
<mailto:[email protected]>> wrote:
Hello Anthony,
For waveform records StreamDevice repeats the format for each element
and optionally reads a separator in between. While this allows to read
a row, it cannot read a column. And it probably does not work with
redirection (I have never tried).
This makes it a bit complicated to read your device. But hopefully not
impossible. You need a few more records.
I understand that the reply always consists of 3 rows. Then I would
try the following:
Have two longin records, one for X and one for X.
Redirect to these records as you do now, but do it 3 times:
Terminator = "\n";
getTBT_XY {
  out "TBT_XY 3";
  in   " %(\$1TBT_Horizontal_tmp)d %(\$1TBT_Vertical_tmp)d";
This processes the two longin records 3 time each. For the waveforms
use two compress records and do a FLNK from the longin records to the
compress records:
record (compress, "$(P)$(R)TBT_Horizontal")
 field (INP,"$(P)$(R)TBT_Horizontal_tmp")
 field (ALG, "Circular Buffer")
 field (NSAM,"3")
The same for Vertical.
I am not quire sure about the compress record settings. Maybe you need
to try a bit.
Maybe you may want to write to the .RES of the compress before
starting. In that case you can use additional seq records.
Hope this helps.
Dirk
On 09.04.2015 23:01, Anthony Pietryla wrote:
I have a device which uses SCPI protocol and returns sets of waveforms
in columns where I can request how many rows to return. For instance I
can query the device for 3 values of position data and it will return 2
columns (X & Y) and 3 rows. I want to read the columns into separate
waveform records. I am having problems with the protocol file for which
I need help.
The database records and the protocol file are listed below. When I
process the record only the first values (first row of data) are written
to each record. With asyn debugging turned on the console shows all
three sets of data:
epics> 2015/04/09 13:52:36.877 L0 wrote
TBT_XY 3
2015/04/09 13:52:36.878 L0 read
 2000   6000
 7143   4286
 4286   1429
caget shows only the first value stored:
caget -# 5 B:Spark:TBT_Horizontal
B:Spark:TBT_Horizontal 5 3333 0 0 0 0
caget -# 5 B:Spark:TBT_Vertical
B:Spark:TBT_Vertical 5 -1111 -3333 0 0 0
The protocol file has:
getTBT_XY {
  Separator = "\n";
  out "TBT_XY 3";
  in   " %(\$1TBT_Horizontal)d %(\$1TBT_Vertical)d";
  ExtraInput = Ignore;
The database records are:
record(waveform, "$(P)$(R)TBT_Horizontal")
  field(DESC, "TBT Horizontal")
  field(DTYP, "stream")
  field(INP,  "@spark.proto getTBT_XY($(P)$(R)) $(PORT)")
  field(NELM, "262144")
  field(EGU,  "um")
  field(FTVL, "LONG")
record(waveform, "$(P)$(R)TBT_Vertical")
  field(DESC, "TBT Vertical")
  field(DTYP, "Soft Channel")
  field(EGU,  "um")
  field(FTVL, "LONG")
When I comment out the “ExtraInput = Ignore;” line in the protocol file
I get error messages:
2015/04/09 15:53:58.170 L0 wrote
TBT_XY 3
2015/04/09 15:53:58.170 L0 asynOctetBase interrupt
2015/04/09 15:53:58.171 L0 read
 3333  -1111
-3333  -5556
-2000      0
2015/04/09 15:53:58.271 L0 B:Spark:TBT_Horizontal: 29 bytes surplus
input "<0a> -3333  -5556<0a> -200..."
2015/04/09 15:53:58.271 L0 B:Spark:TBT_Horizontal: after 13 bytes:
"  3333  -1111"
Anthony Pietryla
Principal Controls Engineer
Advanced Photon Source
Argonne National Laboratory
Phone: 630-252-7430
Fax: 630-252-6123
Re: StreamDevice reading waveforms Dirk Zimoch
StreamDevice reading waveforms Anthony Pietryla
Re: StreamDevice reading waveforms Anthony Pietryla
Prev: RE: CSS Boy and Signed/Unsigned Int Issue ian.bush
Next: Re: Stream device problem with redirection in @mismatch Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: StreamDevice reading waveforms Dirk Zimoch
Next: Re: StreamDevice reading waveforms Dirk Zimoch
