1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Stream device problem with redirection in @mismatch
To: Michael Johnson <[email protected]>
Cc: Tech Talk <[email protected]>
Date: Mon, 13 Apr 2015 16:18:45 +0200
On 10.04.2015 18:50, Michael Johnson wrote:
In Stream, I do not set any terminators (redundant?).
You can set terminators in the startup script using asynOctetSet*Eos or in the StreamDevice protocol. The protocol defined terminators overwrite those in the startup script (StreamDevice restores them when it is done with the protocol).
Program heap: free of bad pointer 98assertion "(uread(BSP_UART_COM1,
LSR) & THRE) != 0" failed: file
"../../../../../../../../__rtems-4.9.2/c/src/lib/libbsp/__i386/pc386/../../i386/shared/__comm/uart.c",
line 585, function: BSP_uart_termios_write_com1
This seems to be outside StreamDevice. But if you send me a stack dump I may able to find out from where it gets called.
(after changing "print" to "printf" to get it to compile)
Maybe this gets called wrongly. I renamed the StreamBuffer method from "printf" to "print" because I found out that on some platforms (RTEMS) printf is actually a macro (for fprintf(stdout, ...))
I really need to publish the current StreamDevice version. :-)
BTW: assertions should not call functions or macros. They should only test but never modify values, because switching them off results in no code at all, thus code like this is "illegal":
assert((uread(BSP_UART_COM1, LSR) & THRE) != 0);
The legal variant would be something like this:
int ureadResult = uread(BSP_UART_COM1, LSR);
assert ((ureadResult & THRE) != 0);
Dirk
Re: Stream device problem with redirection in @mismatch Dirk Zimoch
Stream device problem with redirection in @mismatch ruzickaj
Re: Stream device problem with redirection in @mismatch ruzickaj
Re: Stream device problem with redirection in @mismatch Michael Johnson
Prev: Re: StreamDevice reading waveforms Anthony Pietryla
Next: Re: StreamDevice reading waveforms Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Stream device problem with redirection in @mismatch Michael Johnson
Next: Re: Stream device problem with redirection in @mismatch Dirk Zimoch
