1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: epicsQt/caWtDM and sliders
To: Andrew Rhyder <[email protected]>, John Dobbins <[email protected]>, EPICS mailing list <[email protected]>
Date: Tue, 28 Apr 2015 17:37:03 -0700
Yes, I am referring about changing it dynamically (coarse and fine settings).
With MEDM, if I remember correctly, it is set by clicking on buttons with the power of 10
(0 being the coarse setting, -1 is 10^-1 * coarse setting, etc)
Emmanuel Mayssat
To: [email protected]; [email protected]; [email protected]
Date: Sun, 26 Apr 2015 08:06:31 +0000
Hi Emmanuel
I was assuming that a property setting the slider step size for arrow keys at design time, but you are talking about changing this dynamically? Is this correct?
Regards
Andrew
Sent: Saturday, 25 April 2015 3:19 AM
To: Andrew Rhyder; John Dobbins; EPICS mailing list
Andrew,
To reiterate John's point, the step increment of a slider should be fast and easy to change.
At Lyncean, a typical scenario would be the gross and fine adjustments of RF phase settings of klystrons.
For example, an operator would look at a screen after a bending magnet (diagnostics related to the e- beam energy) and adjust/optimize the RF phases accord to the beam position and shape. This gross and fine tuning approach is used in quite a few places on the accelerator side.
FYI.
Emmanuel Mayssat
Date: Fri, 24 Apr 2015 09:59:23 +0000
Hi John
Firstly, you may not be aware there are two slider controls in the EPCISQ t framework – QESlider that is intended to function just like a standard Qt slider but be connected to a PV, and QEAnalogSlider which is intended to allow slider control but give much richer feedback with a separate readback scale, alarm limits, set points, etc.
Regarding incremental adjustment, both these allow incremental movement using the mouse. Did that not work for you, or is the problem setting the appropriate increments, etc?
Regarding the slider not stopping if the mouse pointer moves off the slider knob, as Emmanuel mentioned the intention is not to emulate MEDM/EDM, but to provide modern style controls, and generally people are now used to the mouse holding onto the control no matter how far the pointer wanders from it (sliders, scroll bars, window edges, etc). Apart from providing familiar interaction I feel that this also allows the user to focus on more important things than exactly where the pointer is in relation to the control. The user knows they have control until they release the button. That said, while the aim is not to emulate medm/edm, the aim IS to provide controls with the required functionality, and I’m happy to discuss any potential changes that make the controls more functional. While I’d argue against this behaviour in a modern GUI, one justification for it may be to ensure slider widgets from both the EPICSQt and caQtDm widget sets can be mixed and matched more comfortably.
Regards
Andrew
From: [email protected] [mailto:[email protected]] On Behalf Of John Dobbins
Sent: Wednesday, 22 April 2015 1:47 AM
Subject: epicsQt/caWtDM and sliders
All,
I am exploring the Qt display managers options. One of the first things I was interested in checking ou t were the sliders. (We have several development machines where manual adjustment is a daily part of operations) I find:
1) The epicQt slide has no increment adjustment (? ) Is there anything that would preclude adding this. I don't know where the default increment is set (methods inherited from Abstract Slider?)
2) The caQtDm slider stops following if the mouse pointer moves off the slider knob (?)  If one attempts to move too fast the slider stops following. (Different behavior than EDM/MEDM/CSS.)
John Dobbins
epicsQt/caWtDM and sliders John Dobbins
RE: epicsQt/caWtDM and sliders Andrew Rhyder
RE: epicsQt/caWtDM and sliders Emmanuel Mayssat
Prev: RE: Scan1 already defined? Mooney, Tim M.
Next: Problem building seq-2-2-1 on Windows Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: epicsQt/caWtDM and sliders Andrew Rhyder
Next: Misunderstanding of epid record ODEL field? Peter Linardakis
