Hi Mark,
Yes, it's there:
peter@peter-Latitude-E7240:~/zed/root/scint/dbd$ grep device\(ao *
scintscal.dbd:device(ao,CONSTANT,devAoSoft,"Soft Channel")
scintscal.dbd:device(ao,CONSTANT,devAoSoftRaw,"Raw Soft Channel")
scintscal.dbd:device(ao,CONSTANT,devAoSoftCallback,"Async Soft Channel")
scintscal.dbd:device(ao,VME_IO,devAoI2C,"I2C DAC") <---------
scintscalRecord.dbd:device(ao,VME_IO,devAoI2C,"I2C DAC")
Pete.
Sent: Wednesday, May 06, 2015 9:38 PM
To: Siddons, David; EPICS Tech-Talk
Subject: RE: stupid problem
Hi Pete,
I think that means your dbd file did not actually get incorporated into the dbd file that got loaded into your IOC. Look at the application dbd file and see if you can find that device(ao...) line in it.
From: [email protected] [[email protected]] on behalf of D Peter Siddons [[email protected]]
Sent: Wednesday, May 06, 2015 8:10 PM
To: EPICS Tech-Talk
Subject: stupid problem
Forgive me, this is probably very dumb.
I have an IOC which uses a scaler record and a bunch of ao records. THe
scaler record dbd file has this line to register the ao device support:
The support routine devAoI2C exists. I use VME_IO because Epics then
nicely parses out the config parameters. However when I run make, I get
this error:
/opt/epics/base/bin/linux-arm/dbToRecordtypeH -I. -I.. -I../O.Common
-I../../../dbd -I/opt/epics/base/dbd ../scintscalRecord.dbd
scintscalRecord.h
Record type "ao" not found for device "I2C DAC"
The build stops there, before it compiles anything else. What am I missing?
Pete.
D. Peter Siddons
Detector Development Group Leader
Bldg. 535B
Photon Sciences Directorate,
Brookhaven National Laboratory
Upton, NY 11973
email: [email protected]
Phone: (631) 344-2738
- RE: stupid problem Mark Rivers
- stupid problem D Peter Siddons
<2015>
2025
2026
<2015>
2025
2026
