1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: stupid problem
To: "Siddons, David" <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Thu, 7 May 2015 02:16:20 +0000
Hi Pete,
I looked more closely at your output:
/opt/epics/base/bin/linux-arm/dbToRecordtypeH  -I. -I.. -I../O.Common -I../../../dbd -I/opt/epics/base/dbd ../scintscalRecord.dbd
scintscalRecord.h
It is running dbToRecordtypeH, which converts a record definition file (xxxRecord.dbd) to a xxxRecord.h.  Is that what you are trying to do?  Does your application define a new record type, scintscanRecord?  It looks like scintscalRecord.dbd is not a record definition file, because it contains entries for device support.  Can you send scintscalRecord.dbd and your Makefile?
Sent: Wednesday, May 06, 2015 8:42 PM
To: Mark Rivers; EPICS Tech-Talk
Hi Mark,
  Yes, it's there:
peter@peter-Latitude-E7240:~/zed/root/scint/dbd$ grep device\(ao *
scintscal.dbd:device(ao,CONSTANT,devAoSoft,"Soft Channel")
scintscal.dbd:device(ao,CONSTANT,devAoSoftRaw,"Raw Soft Channel")
scintscal.dbd:device(ao,CONSTANT,devAoSoftCallback,"Async Soft Channel")
scintscal.dbd:device(ao,VME_IO,devAoI2C,"I2C DAC")    <---------
scintscalRecord.dbd:device(ao,VME_IO,devAoI2C,"I2C DAC")
Pete.
Sent: Wednesday, May 06, 2015 9:38 PM
To: Siddons, David; EPICS Tech-Talk
Hi Pete,
I think that means your dbd file did not actually get incorporated into the dbd file that got loaded into your IOC.  Look at the application dbd file and see if you can find that device(ao...) line in it.
From: [email protected] [[email protected]] on behalf of D Peter Siddons [[email protected]]
Sent: Wednesday, May 06, 2015 8:10 PM
To: EPICS Tech-Talk
Subject: stupid problem
Forgive me, this is probably very dumb.
I have an IOC which uses a scaler record and a bunch of ao records. THe
scaler record dbd file has this line to register the ao device support:
The support routine devAoI2C exists. I use VME_IO because Epics then
nicely parses out the config parameters. However when I run make, I get
this error:
scintscalRecord.h
Record type "ao" not found for device "I2C DAC"
The build stops there, before it compiles anything else. What am I missing?
Pete.
D. Peter Siddons
Detector Development Group Leader
Bldg. 535B
Photon Sciences Directorate,
Brookhaven National Laboratory
Upton, NY 11973
email: [email protected]
Phone: (631) 344-2738
stupid problem D Peter Siddons
RE: stupid problem Mark Rivers
RE: stupid problem Siddons, David
Prev: RE: stupid problem Siddons, David
Next: CSS and multiple IOCs Franklin Fuller
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
