Hi, Recently I want to set up a TCP server and make it to a virtual device by using EPICS. The example testIPServerApp runs normally which doesnot use the devicesupport, but when I use the drvAsynIPServerPortConfigure and start the IOC, I have the problems as followed. ## Register all support components dbLoadDatabase "dbd/AB300.dbd" AB300_registerRecordDeviceDriver pdbbase ## Load record instances #dbLoadRecords("db/xxx.db","user=yuHost") dbLoadRecords("db/devAB300.db","P=AB300,R=,L=0,A=0") drvAsynIPServerPortConfigure("L0","10.40.18.201:5200",2,0,0,0) cd /home/yu/ioc/ab300/iocBoot/iocAB300 iocInit Starting iocInit ############################################################################ ## EPICS R3.14.12.2 $Date: Mon 2011-12-12 14:09:32 -0600$ ## EPICS Base built Aug 10 2014 ############################################################################ 2015/05/07 13:59:52.336 L0 devGpib registerSrqHandler failed asynManager:getInterruptPvt Driver does not support interrupts on interface asynInt32 iocRun: All initialization complete ## Start any sequence programs #seq sncxxx,"user=yuHost" epics> The server can't set up normally, and the communication is failed. I don't understand what these words mean "L0 devGpib registerSrqHandler failed asynManager:getInterruptPvt Driver does not support interrupts on interface asynInt32". I wonder someone who can help me to sovle the problem. Thanks so much! Best regards!
| ANJ, 16 Dec 2015 |
Home
News
About
Talk
Base
Modules
Extensions
