1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy
To: "'Jameson Graef Rollins'" <[email protected]>, Michael Davidsaver <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 13 May 2015 21:20:05 +0000
One suggestion would be to try the latest base 3.14 release, 3.14.12.5.  The 3.14.12.2 version you are running is 3.5 years old, and there have been a number of bug fixes.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Jameson Graef Rollins
Sent: Wednesday, May 13, 2015 4:04 PM
To: Michael Davidsaver; [email protected]
Subject: Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy
On Wed, May 13 2015, Michael Davidsaver <[email protected]> wrote:
> The thread in question (it's sitting in cantProceed()).  It is indeed in
> a PCAS call (see below).
Yes, I see now.  Thanks so much for helping me track this down, Michael!
> One odd thing I notice.  It seems that GDB finds the debug symbols for
> libCom, but not for libcas.  It seems unlikely that this would be true
> if both libraries were from the same build.  Also I note that libca is
> being loaded from a slightly different path (symlink?).
>> Reading symbols from /ligo/apps/ubuntu12/epics-3.14.12.2_long/base/lib/linux-x86_64/libCom.so.3.14...done.
>> Reading symbols from /ligo/apps/ubuntu12/epics-3.14.12.2_long/base/lib/linux-x86_64/libcas.so.3.14...(no debugging symbols found)...done.
>> Reading symbols from /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libca.so.3.14
I think this is just a symlink issue.  We have:
   base -> base-3.14.12.2/
> This might just be a quirk of GDB searching though.  Can you check on a
> running process ("cat /proc/<pid>/maps") to see which libraries were loaded?
I include the full list of loaded EPICS library below [0].
> Also, running "ldd -v _pcas.so" might be interesting.
I'm unable to find a .so with this name, and in fact I don't see any
object files with the string 'pcas' in the name.  I do however see a
"_cas.so" that's included with the pcaspy package [1].
>> Thread 1 (Thread 0x7f8658d49700 (LWP 26265)):
>> #0  0x00007f8658933d84 in pthread_cond_wait@@GLIBC_2.3.2 () from /lib/x86_64-linux-gnu/libpthread.so.0
>> #1  0x00007f86529ed809 in condWait (mutexId=0x301f080, condId=0x301f0a8) at ../../../src/libCom/osi/os/posix/osdEvent.c:75
>> #2  epicsEventWait (pevent=0x301f080) at ../../../src/libCom/osi/os/posix/osdEvent.c:137
>> #3  0x00007f86529ec158 in epicsThreadSuspendSelf () at ../../../src/libCom/osi/os/posix/osdThread.c:557
>> #4  0x00007f86529e2d05 in cantProceed (msg=<optimized out>) at ../../../src/libCom/misc/cantProceed.c:69
>> #5  0x00007f8652568525 in casPVI::getExtServer() const () from /ligo/apps/ubuntu12/epics-3.14.12.2_long/base/lib/linux-x86_64/libcas.so.3.14
>> #6  0x00007f8652c2efa3 in PV::postEvent (this=0x30a0200, value=...) at pcaspy/pv.cpp:83
>> #7  0x00007f8652c1fdc9 in _wrap_PV_postEvent (args=<optimized out>) at pcaspy/casdef_wrap.cpp:9193
>> #8  0x0000000000571b58 in PyEval_EvalFrameEx ()
Ok!  So what's to be done here?  Is this a problem in the pcaspy SWIG
bindings, or in libcas?  I can't see anything obvious that is being
called incorrectly:
https://bazaar.launchpad.net/~epics-core/epics-base/3.14/view/head:/src/cas/generic/casPVI.cc#L320
jamie.
[0] $ sudo cat /proc/2497/maps  | grep epics
7ff3f0611000-7ff3f062c000 r-xp 00000000 00:14 83495166                   /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libdbStaticIoc.so.3.14
7ff3f062c000-7ff3f082b000 ---p 0001b000 00:14 83495166                   /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libdbStaticIoc.so.3.14
7ff3f082b000-7ff3f082c000 r--p 0001a000 00:14 83495166                   /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libdbStaticIoc.so.3.14
7ff3f082c000-7ff3f082d000 rw-p 0001b000 00:14 83495166                   /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libdbStaticIoc.so.3.14
7ff3f082f000-7ff3f086b000 r-xp 00000000 00:14 83495480                   /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libdbIoc.so.3.14
7ff3f086b000-7ff3f0a6a000 ---p 0003c000 00:14 83495480                   /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libdbIoc.so.3.14
7ff3f0a6a000-7ff3f0a6c000 r--p 0003b000 00:14 83495480                   /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libdbIoc.so.3.14
7ff3f0a6c000-7ff3f0a6e000 rw-p 0003d000 00:14 83495480                   /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libdbIoc.so.3.14
7ff3f0a70000-7ff3f0ad0000 r-xp 00000000 00:14 83494965                   /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libca.so.3.14
7ff3f0ad0000-7ff3f0ccf000 ---p 00060000 00:14 83494965                   /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libca.so.3.14
7ff3f0ccf000-7ff3f0cd3000 r--p 0005f000 00:14 83494965                   /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libca.so.3.14
7ff3f0cd3000-7ff3f0cd5000 rw-p 00063000 00:14 83494965                   /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libca.so.3.14
7ff3f141f000-7ff3f142c000 r-xp 00000000 00:14 83495846                   /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libasIoc.so.3.14
7ff3f142c000-7ff3f162b000 ---p 0000d000 00:14 83495846                   /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libasIoc.so.3.14
7ff3f162b000-7ff3f162c000 r--p 0000c000 00:14 83495846                   /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libasIoc.so.3.14
7ff3f162c000-7ff3f162d000 rw-p 0000d000 00:14 83495846                   /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libasIoc.so.3.14
7ff3f162e000-7ff3f166e000 r-xp 00000000 00:14 83498603                   /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libcas.so.3.14
7ff3f166e000-7ff3f186e000 ---p 00040000 00:14 83498603                   /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libcas.so.3.14
7ff3f186e000-7ff3f1871000 r--p 00040000 00:14 83498603                   /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libcas.so.3.14
7ff3f1871000-7ff3f1872000 rw-p 00043000 00:14 83498603                   /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libcas.so.3.14
7ff3f1872000-7ff3f189f000 r-xp 00000000 00:14 83496980                   /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libgdd.so.3.14
7ff3f189f000-7ff3f1a9f000 ---p 0002d000 00:14 83496980                   /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libgdd.so.3.14
7ff3f1a9f000-7ff3f1aa0000 r--p 0002d000 00:14 83496980                   /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libgdd.so.3.14
7ff3f1aa0000-7ff3f1aa1000 rw-p 0002e000 00:14 83496980                   /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libgdd.so.3.14
7ff3f1aa1000-7ff3f1af4000 r-xp 00000000 00:14 83494540                   /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libCom.so.3.14
7ff3f1af4000-7ff3f1cf4000 ---p 00053000 00:14 83494540                   /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libCom.so.3.14
7ff3f1cf4000-7ff3f1cf7000 r--p 00053000 00:14 83494540                   /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libCom.so.3.14
7ff3f1cf7000-7ff3f1cf9000 rw-p 00056000 00:14 83494540                   /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libCom.so.3.14
7ff3f1cfa000-7ff3f1d2a000 r-xp 00000000 00:14 83760456                   /ligo/apps/ubuntu12/epics-3.14.12.2_long/pyext/pcaspy-0.4.1/lib/python2.7/site-packages/pcaspy/_cas.so
7ff3f1d2a000-7ff3f1f2a000 ---p 00030000 00:14 83760456                   /ligo/apps/ubuntu12/epics-3.14.12.2_long/pyext/pcaspy-0.4.1/lib/python2.7/site-packages/pcaspy/_cas.so
7ff3f1f2a000-7ff3f1f2b000 r--p 00030000 00:14 83760456                   /ligo/apps/ubuntu12/epics-3.14.12.2_long/pyext/pcaspy-0.4.1/lib/python2.7/site-packages/pcaspy/_cas.so
7ff3f1f2b000-7ff3f1f2e000 rw-p 00031000 00:14 83760456                   /ligo/apps/ubuntu12/epics-3.14.12.2_long/pyext/pcaspy-0.4.1/lib/python2.7/site-packages/pcaspy/_cas.so
[1] $ ldd -v /ligo/apps/ubuntu12/epics/pyext/pcaspy-0.4.1/lib/python2.7/site-packages/pcaspy/_cas.so
	linux-vdso.so.1 =>  (0x00007ffd619da000)
	libCom.so.3.14 => /ligo/apps/ubuntu12/epics-3.14.12.2_long/base/lib/linux-x86_64/libCom.so.3.14 (0x00007f3209706000)
	libgdd.so.3.14 => /ligo/apps/ubuntu12/epics-3.14.12.2_long/base/lib/linux-x86_64/libgdd.so.3.14 (0x00007f32094d7000)
	libcas.so.3.14 => /ligo/apps/ubuntu12/epics-3.14.12.2_long/base/lib/linux-x86_64/libcas.so.3.14 (0x00007f3209292000)
	libasIoc.so.3.14 => /ligo/apps/ubuntu12/epics-3.14.12.2_long/base/lib/linux-x86_64/libasIoc.so.3.14 (0x00007f3209083000)
	libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f3208d6c000)
	libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f3208b55000)
	libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f3208938000)
	libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f320857a000)
	libreadline.so.6 => /lib/x86_64-linux-gnu/libreadline.so.6 (0x00007f3208337000)
	librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f320812f000)
	libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f3207f2b000)
	libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f3207c2e000)
	libca.so.3.14 => /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libca.so.3.14 (0x00007f32079c9000)
	libdbIoc.so.3.14 => /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libdbIoc.so.3.14 (0x00007f3207787000)
	libdbStaticIoc.so.3.14 => /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libdbStaticIoc.so.3.14 (0x00007f3207569000)
	/lib64/ld-linux-x86-64.so.2 (0x00007f3209b95000)
	libtinfo.so.5 => /lib/x86_64-linux-gnu/libtinfo.so.5 (0x00007f3207341000)
	Version information:
	/ligo/apps/ubuntu12/epics/pyext/pcaspy-0.4.1/lib/python2.7/site-packages/pcaspy/_cas.so:
		libgcc_s.so.1 (GCC_3.0) => /lib/x86_64-linux-gnu/libgcc_s.so.1
		libpthread.so.0 (GLIBC_2.2.5) => /lib/x86_64-linux-gnu/libpthread.so.0
		libc.so.6 (GLIBC_2.14) => /lib/x86_64-linux-gnu/libc.so.6
		libc.so.6 (GLIBC_2.4) => /lib/x86_64-linux-gnu/libc.so.6
		libc.so.6 (GLIBC_2.2.5) => /lib/x86_64-linux-gnu/libc.so.6
		libc.so.6 (GLIBC_2.3.4) => /lib/x86_64-linux-gnu/libc.so.6
		libstdc++.so.6 (CXXABI_1.3) => /usr/lib/x86_64-linux-gnu/libstdc++.so.6
		libstdc++.so.6 (GLIBCXX_3.4) => /usr/lib/x86_64-linux-gnu/libstdc++.so.6
	/ligo/apps/ubuntu12/epics-3.14.12.2_long/base/lib/linux-x86_64/libCom.so.3.14:
		librt.so.1 (GLIBC_2.2.5) => /lib/x86_64-linux-gnu/librt.so.1
		libdl.so.2 (GLIBC_2.2.5) => /lib/x86_64-linux-gnu/libdl.so.2
		libpthread.so.0 (GLIBC_2.3.2) => /lib/x86_64-linux-gnu/libpthread.so.0
		libc.so.6 (GLIBC_2.15) => /lib/x86_64-linux-gnu/libc.so.6
		libc.so.6 (GLIBC_2.3) => /lib/x86_64-linux-gnu/libc.so.6
		libm.so.6 (GLIBC_2.2.5) => /lib/x86_64-linux-gnu/libm.so.6
	/ligo/apps/ubuntu12/epics-3.14.12.2_long/base/lib/linux-x86_64/libgdd.so.3.14:
	/ligo/apps/ubuntu12/epics-3.14.12.2_long/base/lib/linux-x86_64/libcas.so.3.14:
	/ligo/apps/ubuntu12/epics-3.14.12.2_long/base/lib/linux-x86_64/libasIoc.so.3.14:
	/usr/lib/x86_64-linux-gnu/libstdc++.so.6:
		ld-linux-x86-64.so.2 (GLIBC_2.3) => /lib64/ld-linux-x86-64.so.2
		libgcc_s.so.1 (GCC_4.2.0) => /lib/x86_64-linux-gnu/libgcc_s.so.1
		libgcc_s.so.1 (GCC_3.3) => /lib/x86_64-linux-gnu/libgcc_s.so.1
		libc.so.6 (GLIBC_2.3.2) => /lib/x86_64-linux-gnu/libc.so.6
	/lib/x86_64-linux-gnu/libgcc_s.so.1:
	/lib/x86_64-linux-gnu/libpthread.so.0:
		ld-linux-x86-64.so.2 (GLIBC_2.2.5) => /lib64/ld-linux-x86-64.so.2
		ld-linux-x86-64.so.2 (GLIBC_PRIVATE) => /lib64/ld-linux-x86-64.so.2
		libc.so.6 (GLIBC_PRIVATE) => /lib/x86_64-linux-gnu/libc.so.6
	/lib/x86_64-linux-gnu/libc.so.6:
	/lib/x86_64-linux-gnu/libreadline.so.6:
		libc.so.6 (GLIBC_2.11) => /lib/x86_64-linux-gnu/libc.so.6
	/lib/x86_64-linux-gnu/librt.so.1:
		libpthread.so.0 (GLIBC_PRIVATE) => /lib/x86_64-linux-gnu/libpthread.so.0
	/lib/x86_64-linux-gnu/libdl.so.2:
	/lib/x86_64-linux-gnu/libm.so.6:
	/ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libca.so.3.14:
	/ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libdbIoc.so.3.14:
	/ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libdbStaticIoc.so.3.14:
	/lib/x86_64-linux-gnu/libtinfo.so.5:
Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Michael Davidsaver
"epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Jameson Graef Rollins
Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Jameson Graef Rollins
Prev: Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Jameson Graef Rollins
Next: Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
