1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Question about device support
To: EPICS Tech Talk <[email protected]>
Date: Fri, 15 May 2015 10:06:28 +0200
Hi Florian,
On 15/05/2015 08:51, Florian Feldbauer wrote:
I'm currently working together with the company iseg Spezialelektronik GmbH
to develop EPICS device support for their high voltage power supplies.
Two questions came up so far:
1) It is possible that some Control values change their values.
     Can the device support in such a case change the value of a bo record?
     Will the record be processed when changing its value from device
support?
Yes. See
   http://www.aps.anl.gov/epics/tech-talk/2014/msg01947.php
and the other mails of that thread for more details.
2)  Is it possible to give this timestamp through the device support to
the record?
     From the record reference manual I guess not...
This is supported via setting the TSE field to "-2". Documented at:
   https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14_dbCommon
Hope this helps,
~Ralph
Question about device support Florian Feldbauer
Prev: Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Wang Xiaoqiang (PSI)
Next: RE: Question about device support Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Question about device support Florian Feldbauer
