Hi Michael, Jamie,
Thanks for the hints. In pcaspy library, the PV instances are created on startup and live until application quits.
The casPV::destroy method is not implemented.
https://github.com/paulscherrerinstitute/pcaspy/blob/master/pcaspy/pv.cpp#L112
But it does implement casPV::createChannel for access security group.
Will that cause this double free problem?
Best
Xiaoqiang
> On 13 May 2015, at 23:25, Michael Davidsaver <[email protected]> wrote:
> On 05/13/2015 05:03 PM, Jameson Graef Rollins wrote:
>> I think this is just a symlink issue.
> Ok
>> ... I do however see a
>> "_cas.so" that's included with the pcaspy package [1].
> This is the one I meant. This all looks normal.
> So I'm 0 for 3 so far :)
>>>> Thread 1 (Thread 0x7f8658d49700 (LWP 26265)):
>>>> #4 0x00007f86529e2d05 in cantProceed (msg=<optimized out>) at ../../../src/libCom/misc/cantProceed.c:69
>>>> #5 0x00007f8652568525 in casPVI::getExtServer() const () from /ligo/apps/ubuntu12/epics-3.14.12.2_long/base/lib/linux-x86_64/libcas.so.3.14
>>>> #6 0x00007f8652c2efa3 in PV::postEvent (this=0x30a0200, value=...) at pcaspy/pv.cpp:83
>>>> #7 0x00007f8652c1fdc9 in _wrap_PV_postEvent (args=<optimized out>) at pcaspy/casdef_wrap.cpp:9193
>>>> #8 0x0000000000571b58 in PyEval_EvalFrameEx ()
>> Ok! So what's to be done here? Is this a problem in the pcaspy SWIG
>> bindings, or in libcas? I can't see anything obvious that is being
>> called incorrectly:
> In my experience, when pthread_mutex_unlock fails w/ EINVAL it is either
> a sign of memory corruption, or that the lock has already been free'd
> (w/ pthread_mutex_destory).
> Given that the process doesn't crash I'm guessing its the later.
> Is your application creating, or more importantly destroying, casPVI
> instances when this error appears? A race during destruction would
> probably explain things.
> Michael
- Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Jameson Graef Rollins
- "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Jameson Graef Rollins
- Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Michael Davidsaver
Question about device support Florian Feldbauer
Re: Question about device support Ralph Lange
<2015>
2025
2026
<2015>
2025
2026
