On Fri, May 15 2015, "Wang Xiaoqiang (PSI)" <[email protected]> wrote:
> Thanks for the hints. In pcaspy library, the PV instances are created on startup and live until application quits.
> The casPV::destroy method is not implemented.
> https://github.com/paulscherrerinstitute/pcaspy/blob/master/pcaspy/pv.cpp#L112
How is the garbage collection handled? Since the problem does seem to
occur when subscriptions are disconnected, presumably something is
destroyed at that point.
> But it does implement casPV::createChannel for access security group.
> Will that cause this double free problem?
FWIW we're not using any access control in our application.
jamie.
signature.asc
Description: PGP signature
- Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Michael Davidsaver
- "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Jameson Graef Rollins
- Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Jameson Graef Rollins
- Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Wang Xiaoqiang (PSI)
Re: Expected database load times Andrew Johnson
<2015>
2025
2026
<2015>
2025
2026
