1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Question about device support
To: EPICS Tech Talk <[email protected]>
Cc: Florian Feldbauer <[email protected]>
Date: Mon, 25 May 2015 19:38:46 +0300
Florian Feldbauer <[email protected]> writes:
> Do you have an idea how to implement this addressing scheme using only
> _one_ asynPortDriver?  The hole device support should to be easy to
> configure...
Is this because you need to have only one TCP/IP connection (SOAP?) to
some RPC-server (ISEG iCS?). You could have one port per ISEG module if
you share some connection object with asynPortDriver instances, and use
the address to indicate the channel for the operation.
I think the addressing would be quite clear in this case, since each
port could be configured to know the (crate, node, module) part.
Jani Hakala
Question about device support Florian Feldbauer
RE: Question about device support Mark Rivers
Re: Question about device support Florian Feldbauer
Prev: RE: Question about device support Mark Rivers
Next: Draft requirements document for enhanced EPICS motor support Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Question about device support Michael Davidsaver
Next: EPICS Base 3.15.2 released Ralph Lange
