On 06/26/2015 10:42 AM, Florian Feldbauer wrote:
> Hey Michael,
> thanks for the quick answer.
> Looking at your code, I'm doing in principal the same.
> Instead of having a special flag I'm setting PACT = true
> as Ralph suggested.
> But even when I use your method with the sync flag
> I have the same problem:
> The device supports updates RVAL of the bo,
> but VAL is not changed.
> Do I have to set VAL explicitly from device support in this case?
Yes.
The logic in the process() function of boRecord assumes that VAL updated
before processing begins (as is typical of output recordtypes) and
updates RVAL from VAL before calling into device support.
Since you are doing something different you'll need to set VAL yourself.
https://github.com/epics-base/epics-base/blob/3.16/src/std/rec/boRecord.c#L224
In my example I do this for aoRecord
https://github.com/mdavidsaver/pscdrv/blob/master/coreApp/src/devPSCSingle.cpp#L194
- Question about device support Florian Feldbauer
- RE: Question about device support Mark Rivers
- Re: Question about device support Florian Feldbauer
- Re: Question about device support Ralph Lange
- Re: Question about device support Michael Davidsaver
RE: IOC without iocsh Allison, Stephanie
RE: IOC without iocsh Mooney, Tim M.
<2015>
2025
2026
Re: Question about device support Jani Hakala
<2015>
2025
2026
