Subject: |
Re: in 3.15.2 the file aSubRecord.h is not properly generated by dbdToRecordtypeH.pl |
Andrew Johnson <[email protected]> |
To: |
Date: |
Wed, 3 Jun 2015 08:52:59 -0500 |
Hi Yves,
On 06/03/2015 08:36 AM, Yves Lussignol wrote:
> I found the following problem when compiling the gensub record module
> with EPICS base 3.15.2, but it also exists for the aSub record: the
> record field "NOT" is generated as "epicsUInt32 NOT" instead of
> "epicsUInt32 not".
> typedef struct aSubRecord {
> epicsUInt32 nos; /* Max. elements in S */
> epicsUInt32 NOT; /* Max. elements in T */
> epicsUInt32 nou; /* Max. elements in U */
> } aSubRecord;
This is actually deliberate behaviour, because in C++ the lower-case
word "not" is a keyword which cannot be used as an identifier name. The
Perl scripts that convert record.dbd files into a record.h file have a
list of C and C++ keywords and other names which they do not allow to be
used as field names. If we didn't do that, EPICS users would not be able
to write aSub and genSub record subroutines in C++.
The simplest way to avoid using such a keyword is to leave the name in
upper case, hence the structure definition you quoted above.
- Andrew
Light thinks it travels faster than anything but it is wrong.
No matter how fast light travels, it finds the darkness has
always got there first, and is waiting for it.
-- Terry Pratchett, Reaper Man
- in 3.15.2 the file aSubRecord.h is not properly generated by dbdToRecordtypeH.pl Yves Lussignol
in 3.15.2 aSubRecord.h is not properly generated by dbdToRecordtypeH.pl Lussignol Yves
RE: asynPortDriver deadlock when using asynOctet Mark Rivers
<2015>
2025
2026
<2015>
2025
2026
