1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: in 3.15.2 aSubRecord.h is not properly generated by dbdToRecordtypeH.pl
Date: Wed, 3 Jun 2015 13:48:54 +0000
I found the following problem when compiling the gensub record module with EPICS base 3.15.2, but it also exists with the aSub record: the record field "NOT" is generated as "epicsUInt32 NOT" instead of "epicsUInt32 not" in aSubRecord.h.
typedef struct aSubRecord {
    epicsUInt32         nos;        /* Max. elements in S */
    epicsUInt32         NOT;        /* Max. elements in T */
    epicsUInt32         nou;        /* Max. elements in U */
} aSubRecord;
Yves
Prev: in 3.15.2 the file aSubRecord.h is not properly generated by dbdToRecordtypeH.pl Yves Lussignol
Next: Re: in 3.15.2 the file aSubRecord.h is not properly generated by dbdToRecordtypeH.pl Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: in 3.15.2 the file aSubRecord.h is not properly generated by dbdToRecordtypeH.pl Andrew Johnson
Next: Using devIocStats under dynamic epics build. Alireza Panna
