1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Using devIocStats under dynamic epics build.
Date: Wed, 3 Jun 2015 18:15:35 -0400
Hello tech-talkers,
When compiling a stream based app that uses deviocstat support, I encounter the following error:
No rule to make target `../../../lib/windows-x64/devIocStats.lib'
base (3.14.12.4) is compiled as dynamic for the windows-x64 arch.
When compiling the same app under linux-x64 everything works fine. I am assuming the issue is that I did not compile epics and synapps support statically in the windows OS. If that is the issue then how do I use deviocstats successfully for dynamic builds. I am using devIocStats-3-1-7 currently.
Any help/suggestions is much appreciated.
Alireza Panna
University of Maryland, College Park
RE: Using devIocStats under dynamic epics build. Mark Rivers
Prev: RE: asynPortDriver deadlock when using asynOctet Mark Rivers
Next: RE: Using devIocStats under dynamic epics build. Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: in 3.15.2 aSubRecord.h is not properly generated by dbdToRecordtypeH.pl Lussignol Yves
