1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Macros limited (edition ;-)
Date: Fri, 5 Jun 2015 22:04:24 +0000
Hi Andrew,
I reopen a Thread about tricky behavior of dbloadtemplate which can not translates more 100 macros in one shot.
I have these errors when I start a softIOC
More than dbTemplateMaxVars = 100 macro variables used
Substitution file error.
line 17: 'VANODEMES__FUNCTION'
line 18: 'TDISMES__FUNCTION'
line 18: 'DEBEAUDISMES__OFFSET'
line 18: 'LOCKSTATE__OFFSET'
/admin/spiral2/scripts/bootIOC: line 80: 16751 Erreur de segmentation  ./$IOC_CMD_SCRIPT
I have changed the  value of  dbTemplateMaxVars to 900 in  base/src/dbtools/dbLoadTemplate.y but the value shown in error messages stills to 100.
I am sure I made something wrong, but in earlier EPICS version I remenber having changed the max values inside dbtools  and just having type a "make" to see changes.
What must I do to push changes with this new version of dbtools?
Thanks for your help.
Dominique.
Subject: 	Re: Macros limited (edition ;-)
To: 	[email protected]
Cc: 	Touchard Dominique <[email protected]>
Date: 	Fri, 5 Jul 2013 10:39:43 -0500
Hi Dominique,
On 2013-07-05 Dominique Touchard wrote:
> It seems that the number of macros for template substitutions during IOC
> startup is limited to 100. Over, a segmentation fault stop the IOCs.
> Is this number correct? Is there any reason?
I was surprised but you're right, src/dbtools/dbLoadTemplate.y defines
VAR_MAX_VARS as 100 which sets a limit to the number of variables that
dbLoadTemplate() can handle.  It also defines VAR_MAX_VAR_STRING as 5000
setting the maximum size of the "variable=value,..." string which it
constructs to pass to dbLoadRecords().  In neither case though does it check
when the storage limit set by those macros gets exceeded, thus causing a
crash.  This is obviously unacceptable and needs to be fixed in Base.
To get around this limit for a particular application you could do the
template expansion on the host at build time using the msi (Macro
Substitution and Include) program which is distributed as an EPICS extension.
You can also increase the above values in your source code and rebuild base,
which might be a simpler fix in some circumstances.
I have filed a bug-report for this issue.  If someone feels inclined to look
at rewriting the dbLoadTemplate() code to remove these limitations please let
me know.
    https://bugs.launchpad.net/epics-base/+bug/1198234
- Andrew
Re: Macros limited (edition ;-) Andrew Johnson
Prev: EPICS support for LinMot E1100-GP Marcin Lukaszewski
Next: Re: Macros limited (edition ;-) Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
