1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Macros limited (edition ;-)
To: <[email protected]>
Date: Fri, 5 Jun 2015 17:18:42 -0500
Hi Dominique,
On 06/05/2015 05:04 PM, Touchard Dominique wrote:
> I have these errors when I start a softIOC
> More than dbTemplateMaxVars = 100 macro variables used
> Substitution file error.
> line 17: 'VANODEMES__FUNCTION'
You can change the value of dbTemplateMaxVars from your IOC's startup
script with the line
    var dbTemplateMaxVars 900
Instead of modifying the default value in your copy of Base, you just
have to put that line anywhere before your dbLoadTemplate command in the
script.
Hope this helps,
- Andrew
Light thinks it travels faster than anything but it is wrong.
No matter how fast light travels, it finds the darkness has
always got there first, and is waiting for it.
    -- Terry Pratchett, Reaper Man
RE: Macros limited (edition ;-) Touchard Dominique
Prev: RE: Macros limited (edition ;-) Touchard Dominique
Next: CSS performance Marcio Alexandre Barbosa
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
