At least, I can tell "MEDM, ALH, Alh_printer, alh_DB, StripTool" can be
compiled on Debian 7 and 8. And I can confirm StripTool is working well
on both.
Note that motif package for
* Debian 7 (Wheezy) : lesstif2-dev
* Debian 8 (Jessie) : libmotif-dev,
and the enclosed quick and dirty patch for StripTool.
In addition, in the file CONFIG_SITE.linux-x86_64.linux-x86_64 in
EXTENSIONS/configure/os, I assign the right path for LIB and INC for X11
and MOTIF.
X11_LIB=/usr/lib/x86_64-linux-gnu
X11_INC=/usr/include
MOTIF_LIB=/usr/lib/x86_64-linux-gnu
MOTIF_INC=/usr/include
I hope it will help for your RHEL 7.0 system.
Han
On 06/19/2015 04:24 AM, Farnsworth, Richard I. wrote:
Has anyone had experiences with the latest REDHAT release (RHEL 7.0) and
any of the Motif based applications - MEDM, ALH, Striptool, EDM etc.
Or, for that matter any other very recent release of Linux.
Thanks
Richard Farnsworth
Controls group leader
APS, Argonne.
Jeong Han Lee, Dr.rer.nat.
Rare Isotope Science Project
Institute for Basic Science
Daejeon, South Korea
tel : +82-42-878-8733
fax : +82-42-878-8799
diff -rupN StripTool2_5_16_0/Strip.c StripTool2_5_16_0_jhlee/Strip.c
--- StripTool2_5_16_0/Strip.c 2015-04-01 17:00:55.942083479 +0900
+++ StripTool2_5_16_0_jhlee/Strip.c 2015-04-01 16:57:09.380085523 +0900
@@ -1841,7 +1841,7 @@ int Strip_writeconfig (Strip
if ((ret_val = StripConfig_write (si->config, f, m)))
StripConfig_setattr (si->config, STRIPCONFIG_FILENAME, fname, 0);
- StripConfig_setattr (si->config, STRIPCONFIG_TITLE, basename (fname), 0);
+ StripConfig_setattr (si->config, STRIPCONFIG_TITLE, basename_s (fname), 0);
StripConfigMask_set (&m, SCFGMASK_FILENAME);
StripConfigMask_set (&m, SCFGMASK_TITLE);
StripConfig_update (si->config, m);
@@ -1863,7 +1863,7 @@ int Strip_readconfig (Strip
if ((ret_val = StripConfig_load (si->config, f, m)))
diff -rupN StripTool2_5_16_0/StripDialog.c StripTool2_5_16_0_jhlee/StripDialog.c
--- StripTool2_5_16_0/StripDialog.c 2015-04-01 17:00:55.942083479 +0900
+++ StripTool2_5_16_0_jhlee/StripDialog.c 2015-04-01 16:57:43.394757076 +0900
@@ -3396,7 +3396,7 @@ static void save_config (StripDi
if (StripConfig_write (sd->config, f, mask))
StripConfig_setattr (sd->config, STRIPCONFIG_FILENAME, fname, 0);
- StripConfig_setattr (sd->config, STRIPCONFIG_TITLE, basename (fname), 0);
+ StripConfig_setattr (sd->config, STRIPCONFIG_TITLE, basename_s (fname), 0);
StripConfigMask_clear (&mask);
StripConfigMask_set (&mask, SCFGMASK_FILENAME);
StripConfigMask_set (&mask, SCFGMASK_TITLE);
@@ -3428,7 +3428,7 @@ static void load_config (StripDi
if (StripConfig_load (sd->config, f, mask))
StripConfig_update (sd->config, mask);
diff -rupN StripTool2_5_16_0/StripMisc.c StripTool2_5_16_0_jhlee/StripMisc.c
--- StripTool2_5_16_0/StripMisc.c 2015-04-01 17:00:55.942083479 +0900
+++ StripTool2_5_16_0_jhlee/StripMisc.c 2015-04-01 16:58:09.312181901 +0900
@@ -579,7 +579,7 @@ static void Question_cb(Widget w, XtPoin
-char *basename (char *path)
+char *basename_s (char *path)
char *p = 0;
diff -rupN StripTool2_5_16_0/StripMisc.h StripTool2_5_16_0_jhlee/StripMisc.h
--- StripTool2_5_16_0/StripMisc.h 2015-04-01 17:00:55.942083479 +0900
+++ StripTool2_5_16_0_jhlee/StripMisc.h 2015-04-01 16:58:36.079847822 +0900
@@ -235,11 +235,11 @@ char *dbl2str (double,
char *int2str (int x, char buf[], int n);
-/* basename
+/* basename_s
* Returns the filename portion of a fully qualified path.
-char *basename (char *);
+char *basename_s (char *);
void History_MessageBox_popup(char *title,char *btn_txt,char *str);
/* General purpose output routine
- EPICS Motif applications on the latest RHEL (7.0) Farnsworth, Richard I.
Re: EPICS Motif applications on the latest RHEL (7.0) Jemian, Pete R.
UCHAR to BITARRAY CONVERSION ishita bhatia
<2015>
2025
2026
Re: EPICS Motif applications on the latest RHEL (7.0) Mike Westfall
<2015>
2025
2026
