1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: multi-channel analog i/p
To: Stefen Paul <[email protected]>
Date: Wed, 24 Jun 2015 12:54:55 +0000
Hi:
The EPICS Application Developer's Guide really has all the information as far as APIs.
There are several EPICS training session documents available which may be easier to read when you're just getting started, for example 3.3 Custom Device Support.ppt on http://ics-web.sns.ornl.gov/kasemir/train2013/
That shows how you tie a generic routine like this:
   // Read current value for some channel from the hardware
   int simple_read(int channel);
.. to for example an EPICS analog input record: *.dbd file entry to name the device support entry, 'read' routine called by the record which then invokes your simple_read() and places the value into the record's VAL field, ..
It also points out pitfalls; check the "problematic" example that can be found under "3.3 Device Examples".
When you expand a simple example into a real-world example, you'll soon find that your driver might have to setup threads which periodically poll the hardware, handle interrupts, errors, try again etc., so that the EPICS device support can always simply and quickly obtain the current state without delays.
Instead of doing that yourself, many people prefer to use the ASYN framework.
Kay
On Jun 24, 2015, at 3:32 AM, Stefen Paul <[email protected]>
 wrote:
> Is there a comprehensive document/website available telling about including 'driver support' in EPICS  ?
> How can one call vxWorks device driver routines from EPICS records and make the data read by driver routine available to the EPICS records ?
> Like in my case where I have a vxWorks driver for VME based 32-channel analog i/p board. I need to read the h/w through the driver only because of some FIFO design issues. But once the data is read by the driver, I would like to pass each channel's raw data to an individual ai record.
> Thanks,
> Stefen.
> On Tue, Jun 23, 2015 at 6:19 PM, Hartman, Steven M. <[email protected]> wrote:
> > On Jun 23, 2015, at 1:36 AM, Stephen Paul <[email protected]> wrote:
> > Instead , I first want a record and its device support to read all the channels from the board in one go and then pass these values to individual 32 ai records for conversion.
> > Can anyone suggest what type of record I can use before ai record to achieve this ?
> Rather then a record for reading all of the hardware values, your device driver can have a worker thread responsible for reading from the hardware. This can be scheduled either periodically or based on some trigger. Your ai records would then read from the cached values from this worker thread rather then directly from the hardware. There are a number of drivers which take this approach, typically with more complicated hardware with a large number of registers to be read, or having a variety of different data types to support.
> Steven Hartman
> [email protected]
multi-channel analog i/p Stephen Paul
Re: multi-channel analog i/p Hartman, Steven M.
Re: multi-channel analog i/p Stefen Paul
Prev: RE: multi-channel analog i/p Mark Rivers
Next: Re: Direction option for caByte in caQtDM Jameson Graef Rollins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: multi-channel analog i/p Mark Rivers
