1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Direction option for caByte in caQtDM
To: "Mezger Anton Christian \(PSI\)" <[email protected]>, "kthorne\@ligo-la.caltech.edu" <[email protected]>, "tech-talk\@aps.anl.gov" <[email protected]>
Cc: "Brands Helge \(PSI\)" <[email protected]>
Date: Wed, 24 Jun 2015 06:32:41 -0700
On Wed, Jun 24 2015, "Mezger Anton Christian (PSI)" <[email protected]> wrote:
> caQtDM supports caByte in all directions. However in adl2ui the wrong
> default was choosen. You can change that yourself actually by editing
> parser.c and change at line 1783 the instruction that defines the
> default direction to "Right". Otherwise you may change the direction
> in the ui file with the designer. The default will be changed in the
> next release.
Maybe adl2ui could just use to orientation as specified in the adl file,
which I think that's what Keith is looking for.  I don't think you want
to default to any particular orientation, you just want to recreate the
orientation as already specified.
jamie.
Attachment: signature.asc
Description: PGP signature
RE: Direction option for caByte in caQtDM Mezger Anton Christian (PSI)
Prev: Re: multi-channel analog i/p Kasemir, Kay
Next: RE: Direction option for caByte in caQtDM Mezger Anton Christian (PSI)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Direction option for caByte in caQtDM Mezger Anton Christian (PSI)
