Dear All,
One hast o change the default in ad2ui, whilethe problem is that the default direction is not written in the medm file, so that adl2ui needs the same default as medm.
Best regards
Anton
-----Original Message-----
From: Jameson Graef Rollins [mailto:[email protected]]
Sent: Mittwoch, 24. Juni 2015 15:33
To: Mezger Anton Christian (PSI); [email protected]; [email protected]
Cc: Brands Helge (PSI)
Subject: Re: Direction option for caByte in caQtDM
On Wed, Jun 24 2015, "Mezger Anton Christian (PSI)" <[email protected]> wrote:
> caQtDM supports caByte in all directions. However in adl2ui the wrong
> default was choosen. You can change that yourself actually by editing
> parser.c and change at line 1783 the instruction that defines the
> default direction to "Right". Otherwise you may change the direction
> in the ui file with the designer. The default will be changed in the
> next release.
Maybe adl2ui could just use to orientation as specified in the adl file, which I think that's what Keith is looking for. I don't think you want to default to any particular orientation, you just want to recreate the orientation as already specified.
jamie.
- Direction option for caByte in caQtDM Mezger Anton Christian (PSI)
- Re: Direction option for caByte in caQtDM Jameson Graef Rollins
Re: EPICS base-3.14.12.5 installation error Alex George
<2015>
2025
2026
Detecting EPICS record processing Jan Malec
<2015>
2025
2026
