I am not sure what you mean by a "bitArray"? In some sense your asyn record data is already a "bitArray": it is a series of sequential bits in memory. By bitArray do you mean an array of CHAR, UCHAR, or INT32 in which each element of that array only holds a single bit? If so what data type do you want the array values to be?
Taking a step back: what is your end-goal, why do you want the data in a bitArray?
From: [email protected] [[email protected]] on behalf of ishita bhatia [[email protected]]
Sent: Thursday, June 25, 2015 6:17 AM
To: Ralph Lange
Cc: EPICS Tech-Talk
Subject: Re: UCHAR to BitArray conversion
Hello,
How can i get output of mbbiDirect record in form of bitArray ? Is there any record available in VDCT to get such output.
To get understanding of mbbiDirect record i tried following:
I have taken a decimal value (for eg.4 ) in ai record. This value is given as input in mbbiDirect record (for eg. bits). Now when i run ioc, i give command
caget bits.B0
I get output as 1 i.e. just one bit of 100(binary of 4). then when I run caget bits.B1, i get output 0...same caget bits.B1 gives 0.
but as this mbbiDirect gives bit by bit output, i wan't to get output in form of bitArray.
My main requirement is i am getting output from waveform record as waf 4 50 66 64 51(this is the output which i have got from VME using asyn record )which i wan't to convert in binary or bitArray form. So kindly suggest me how to do it without code or even if I create a device support how will i fetch this data (waf 4 50 66 64 5)from VDCT to device support to create the logic.
- Re: UCHAR to BitArray conversion ishita bhatia
- UCHAR to BitArray conversion ishita bhatia
- RE: UCHAR to BitArray conversion Mooney, Tim M.
- Re: UCHAR to BitArray conversion Ralph Lange
RE: UCHAR to BitArray conversion peter.owens
<2015>
2025
2026
<2015>
2025
2026
