Is your device sending this data as a stream of bytes (eg over a serial line)?
If so I would suggest you use stream device to parse your input into 5 mbbiDirect records.
What do you want to do with the “bit array”?
On Behalf Of ishita bhatia
Sent: 25 June 2015 12:18
To: Ralph Lange
Cc: EPICS Tech-Talk
Subject: Re: UCHAR to BitArray conversion
How can i get output of mbbiDirect record in form of
bitArray ? Is there any record available in VDCT to get such output.
To get understanding of mbbiDirect record i tried following:
I have taken a decimal value (for eg.4 ) in
ai record. This value is given as input in mbbiDirect record (for eg. bits). Now when i run ioc, i give command
caget bits.B0
I get output as 1 i.e. just one bit of 100(binary of 4). then when I run
caget bits.B1, i get output 0...same caget bits.B1 gives 0.
but as this mbbiDirect gives bit by bit output, i wan't to get output in form of bitArray.
My main requirement is i am getting output from waveform record as
waf 4 50 66 64 51(this is the output which i have got from VME using asyn record )which i wan't to convert in binary or bitArray form. So kindly suggest me how to do it without code or even if I create a device support how will i fetch this data
(waf 4 50 66 64 5)from VDCT to device support to create the logic.
- UCHAR to BitArray conversion ishita bhatia
- RE: UCHAR to BitArray conversion Mooney, Tim M.
- Re: UCHAR to BitArray conversion Ralph Lange
- Re: UCHAR to BitArray conversion ishita bhatia
RE: UCHAR to BitArray conversion Mark Rivers
RE: CSS performance Shroff, Kunal
<2015>
2025
2026
EPICS base-3.14.12.5 installation error Alex George
<2015>
2025
2026
ANJ, 16 Dec 2015 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
