1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: IOC without iocsh
To: [email protected]
Date: Fri, 26 Jun 2015 12:01:30 -0400
All the IOC shell commands are also C functions which can be called
directly.
Also, if you look in the *Main.cpp file generated by makeBaseApp, there
are two calls to iocsh().  The first with a non-NULL argument reads a
file.  The second call with NULL starts the interactive shell.
https://github.com/epics-base/epics-base/blob/3.16/src/template/base/top/iocApp/src/_APPNAME_Main.cpp
There is also iocshCmd("") which takes a shell command as a string.
> just to be more clear, the application uses the stdin/stdout to control
> its states and I cannot use it for iocsh - how can I create an IOC
> "inside" my existing application ?
That said, you might want to explore alternatives.  The IOC shell is a
handle debugging tool which I'd be reluctant to give up.
Michael
On 06/26/2015 10:29 AM, [email protected] wrote:
> Hi,
> I have developed for a Linux embedded board called uSOP various EPICS IOCs
> that publish different PVs for Belle2 environmental data (temperature,
> humidity);
> to do these tasks I use makeBaseApp.pl scripts to start developing and
> the result is an IOC that provide an iocsh prompt;
> now I have to add, for a new developing activity, some EPICS PVs to an
> exisiting application (not EPICS-enabled) and my question is how to do
> this in a simple and effective way...
> Thanks in advance,
> Gennaro
IOC without iocsh [email protected]
Prev: RE: IOC without iocsh Mooney, Tim M.
Next: Re: IOC without iocsh Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
