1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: epicsExit (); function exits the IOC but the Linux console requires a resest to be operative
To: [email protected]
Date: Tue, 30 Jun 2015 10:05:41 -0400
Is the IOC process returning 0?  This is not normal, and sounds like the
process isn't exiting cleanly.
On 06/30/2015 09:50 AM, Diego Sanz wrote:
> Situation:
> Linux Centos, 6.4
> EPICS Base 3.14.12.4
> asynDriver asyn4-23
> When my IOC application find a situation that I want it to be finished,
> which is the best way to do it? I have used epicsExit(0), and the
> function that I registered for exit is executed correctly, but when the
> IOC shell ends, the console requires to write "reset" command to recover
> the echo of the console, and its correct working. Is there any reason
> for this? is it normal?
> Thanks in advance
> Diego
epicsExit (); function exits the IOC but the Linux console requires a resest to be operative Diego Sanz
Prev: epicsExit (); function exits the IOC but the Linux console requires a resest to be operative Diego Sanz
Next: autosave ---Data coverage l123173
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: epicsExit (); function exits the IOC but the Linux console requires a resest to be operative Andrew Johnson
