1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Sequencer on Windows: co-maintainer needed
To: <[email protected]>
Date: Sat, 11 Jul 2015 12:15:34 +0200
Hello everyone
I am happy to have received an offer from Freddie Akeroyd
<[email protected]> who will from now on act as co-maintainer for the
Sequencer. The web site will be updated accordingly and I hope we can soon
bring you new releases that smoothly build and test on Windows.
Cheers
Ben
Am Donnerstag, 9. Juli 2015, 21:07:57 schrieb Benjamin Franksen:
> I am writing to all interested parties as the current maintainer and
> main developer of the EPICS sequencer. The problem is:
> (1) Seemingly harmless changes to the code organization or in the build
> system (i.e. Makefiles) have the tendency to break the build on Windows.
> (2) Similarly, running the tests can also easily break on Windows due to
> differences in the way processes are started and stopped.
> (3) Now and then I forget to avoid gcc'isms (mostly stuff that's not in
> the C90 standard) which break when trying to compile with native C
> compilers (like Visual Studio).
> I have not done any serious work on Windows for years (perhaps decades).
> My original hope was that I would get some in-house support, i.e. people
> here at HZB who would set up the VMs I need for testing (Windows7 in 32
> and 64 bit, both with Mingw and native compiler), but that did not work
> out. Which means that, for now and in the forseeable future, I will not
> be able to test or even build on Windows, so I cannot rightfully claim
> to support it as a build and target platform for the sequencer. For a
> while Mark River has acted as de-facto co-maintainer (many thanks for
> that!) but his time is understandably limited, given the large number of
> projects he is responsible for.
> This is why I am asking for a volunteer to act as a co-maintainer of the
> sequencer for the Windows side.
> Your job would be to
> (a) Notify me whenever building or running the tests breaks on Windows.
> Ideally this should be automated by extending the Jenkins build farm
> (which is currently maintained by Andrew Johnson) to cover the several
> Windows variants. But even with that, it doesn't make sense for me to
> publish patch after patch waiting hours in between until I find that I
> made a stupid error in a Perl script.
> (b) Help me to react to reports from users about such problems: try to
> reproduce the problem, find out its cause, share your findings (or lack
> of them) with me and the user.
> (c) Try to come up with a solution. Ideally send me a patch that solves
> it. Failing that, collaborate with me via email (or otherwise, perhaps
> meet in a chatroom) exchanging analysis and patches until we get it
> working again.
> You should have Windows machines (VM or real) readily available and
> configured to allow building the sequencer and running the testsuite,
> ideally in (at least) the four variants I listed above. It would be
> perfect if you (or your colleagues) actually used the sequencer on
> Windows because some problems only come up in the real world and/or are
> hard to test automatically.
> It is not necessary to be imtimately familiar with the code base itself,
> as I expect most problems to be of the sort described above: build
> failures and failures in the test system. I will of course help with
> getting started and will answer questions about the code, the build
> system, how the tests work etc, whenever they arise.
> Being available on short notice is also not a requirement: the work can
> usually be postponed a week or two (or longer if necessary) until we
> both have enough time available. But at some point there must be the
> possibility to tightly work together for as long as it takes to fix
> things. (If we are in different time zones this period might stretch
> over a few days.) I expect the need for this kind of close collaboration
> to arise only occasionally, perhaps every few months, with long
> stretches of nothing (noticeable) happening in between.
> If nobody volunteers I fear I'll have to remove any claim (in the
> documentation) that the sequencer supports Windows as a target or build
> platform, acknowlegding what has for a while been the state of things:
> if it breaks on Windows you are (more or less) on your own. Of course I
> will continue to apply patches people send me when they find a fix for a
> problem on Windows, provided it doesn't break anything on Linux.
> Cheers
> Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Attachment: signature.asc
Description: This is a digitally signed message part.
Sequencer on Windows: co-maintainer needed Benjamin Franksen
Prev: Re: Stepper Motor Controllers Mark Rivers
Next: RE: Stepper Motor Controllers Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Sequencer on Windows: co-maintainer needed Benjamin Franksen
Next: new version of STAR EPICS VM (now with Scientific Linux 6 and caQtDM) Jiro Fujita
