1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Stepper Motor Controllers
To: Kevin Peterson <[email protected]>
Cc: "<[email protected]>" <[email protected]>, "[email protected]" <[email protected]>
Date: Sun, 12 Jul 2015 21:51:41 +0000
Clarification:
I just remembered that one does not actually comment out the SmartStageName line, rather one sets the value to a blank string.
For example, these are the first few lines for a UTS100CC stage from one of my stages.ini files:
[UTS100CC@XPS-DRV01]
;--- Unit = mm
;--- Configuration_Comment =
;--- Smart stage name
;SmartStageName = UTS100CC
SmartStageName =
;--- Motor driver model parameters
DriverName = XPS-DRV01
DriverPWMFrequency = 50 ;--- kHz
Note that I have commented out the line
and replaced it with:
SmartStageName =
The purpose of the SmartStageName line is to tell the XPS to read the actual stage model from a chip in the stage during initialization.  This only works with Newport stages of course.  It provides a check that the user has plugged the stages in correctly.  If this line is present, and if the stage model string does not match then initialization will fail.  But if there is a chance that you want to deliberately leave a stage unplugged then setting the SmartStageName to an empty string will allow initialization to succeed even if the stage is disconnected at power-up.
Sent: Friday, July 10, 2015 3:18 PM
To: Kevin Peterson
Cc: <[email protected]>; [email protected]
Subject: Re: Stepper Motor Controllers
That is not true. If you simply comment out the SmartStageName lines in the stages.ini file then the controller works fine with any motor disconnected.
Sent from my iPhone
> On Jul 10, 2015, at 3:10 PM, Kevin Peterson <[email protected]> wrote:
> One disadvantage of the Newport XPS controller is that the controller
> requires its configuration to match the stages that are physically
> connected.  If one stage is disconnected from the controller, none of
> the other axes will be usable until the unused axis is reconfigured to
> be a dummy axis.  For stable setups this isn't an issue.  For
> frequently-changing setups this can be quite annoying.
> Kevin
>> On 7/10/15 9:58 AM, Mark Rivers wrote:
>> We have 11 Newport XPS controllers on our beam lines. In my
>> experience they are much easier to configure than the Delta Tau
>> units. They have a user-friendly Web interface, all parameters are in
>> engineering units, etc. There is an EPICS interface to complex
>> multi-axis coordinated motion with detector triggering, and lots of
>> other auxiliary I/O.
>> Mark
Re: Stepper Motor Controllers Kevin Peterson
Stepper Motor Controllers Mark Davis
Re: Stepper Motor Controllers Mark Rivers
Prev: Re: Sequencer on Windows: co-maintainer needed Benjamin Franksen
Next: Re: Tech-talk Digest, Vol 9, Issue 224 Dimitrios Tsifakis
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Stepper Motor Controllers Mark Rivers
Next: Re: Stepper Motor Controllers Kevin Peterson
