1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: record to record ...
To: Stefen Paul <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Mon, 13 Jul 2015 14:41:26 +0000
Hi Stefen,
I think you don't want to do this.  It's hard enough to write a record that defends itself from all the possible ways and times that its fields can be written to from outside, without having to contend with code that works around the protections EPICS provides.  It's unfortunate that the sub record has no output link; that would probably be a better solution for you.  I don't know all your requirements, but I'd try the aSub record, which has output links, and see if it can accomplish what you want.
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] [[email protected]] on behalf of Stefen Paul [[email protected]]
Sent: Monday, July 13, 2015 9:14 AM
To: EPICS Tech Talk
Subject: record to record ...
Hi
Just wanna know that if we have a 'sub' record then from its subroutine can we directly write into RVAL field of some other records say 'ai' records in the same database.
If the answer is yes then how does one get the address/pointer of other records (ai for example) in the subroutine of 'sub' record ?
Stefen.
record to record ... Stefen Paul
Prev: Re: record to record ... Kasemir, Kay
Next: device support for data in subarray Deepika Thakur
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: record to record ... Ralph Lange
