1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: record to record ...
To: EPICS Tech-Talk <[email protected]>
Date: Wed, 15 Jul 2015 21:22:20 +0200
On July 15, 2015 2:21:49 PM GMT+02:00, Ralph Lange <[email protected]> wrote:
>On 15/07/2015 14:02, Benjamin Franksen wrote:
>> On Monday 13 July 2015 14:35:49 Kasemir, Kay wrote:
>>> In principle, you can read include/link.h to get the 'record'
>pointer
>>> of a link, cast that to the appropriate type, ...
>>> But that's a bad idea because you'd directly access the memory of
>that
>>> other record without it being locked.
>> It is possible to do this correctly, using the runtime database
>access
>> methods: in the init routine you call dbNameToAddr, store the address
>of
>> the dbAddr struct in the record's DPVT and in the subroutine place
>calls
>> to dbScanLock/Unlock around a call to dbPutField.
>Note, though, that by doing this you are evading the lock-set
>mechanism,
>which might get you into trouble - depending on your database
>configuration.
>Records interconnected by links are put into a common lock-set to avoid
>stack overflow situations with circular links. The described method
>effectively creates a link that will be undetected by the lock-set
>forming algorithm.
>Obviously, disabling safety functions will not affect you in safe
>situations, but...
>Cheers,
>~Ralph
Ehhhhh ... wrong.
Lock-sets prevent multiple threads from processing records of the same interconnected set at the same time. The PACT field mechanism protects against circular links.
I should know that.
Sorry for creating confusion,
~Ralph
record to record ... Stefen Paul
Re: record to record ... Kasemir, Kay
Re: record to record ... Benjamin Franksen
Re: record to record ... Ralph Lange
Prev: Re: using motor / steppermotor record for Trinamic TMCM-351 controller Ron Sluiter
Next: Re: Linux vs. RTOS: cost and security; was: Stepper Motor Controllers Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: record to record ... Ralph Lange
Next: RE: record to record ... Mooney, Tim M.
