1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Stepper Motor Controllers
To: "[email protected] ([email protected])" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 14 Jul 2015 09:26:10 +0000
Hi Mark,
Another interesting feature of the Delta Tau is it can run a PID algorithm and close the loop around a stepper without an encoder.  Adding an encoder and closing the loop on that is also possible.
With the Galil, steppers are run in open loop mode.  A stepper position maintenance mode is available which is similar to the motor record retry facility.  When using a Galil if you want true closed loop control of a stepper you must have an encoder, and a motor amplifier such as the Technosoft that allows the stepper to be controlled as a servo (Galil configured for servo mtr).  I've got many stages running this way, and the performance is good.  Using a servo motor, the Galil runs true PID, like most controllers now days.
Best wishes,
Dr. Mark Clift
Senior Controls Engineer
Australian Synchrotron
800 Blackburn Road
Clayton 3168
Ph: +613 8540 4264
Fax: +613 8540 4200
Prev: Conversion to Hexadecimal ishita bhatia
Next: RE: Conversion to Hexadecimal Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Stepper Motor Controllers Mark Clift
Next: caQtDM related questions Alireza Panna
