Subject: |
using motor / steppermotor record for Trinamic TMCM-351 controller |
Christian Pauly <[email protected]> |
To: |
[email protected] |
Date: |
Wed, 15 Jul 2015 10:20:58 +0200 |
Dear experts
I guess i need your help / advice again:
We have bought a Trinamic TMCM-351 3-axis step motor controller, and
want to control a XY-table with this.
It communicates via USB / serial, and we want to run the soft IOC on a
connected Raspberry Pi under Linux.
From what i understand by scanning through various EPICS pages and
docs, the motor module/record, or, alternatively, the steppermotor
module should provide all i need to work with such a multi-axis setup
under EPICS.
However, from what i learn from the motor record documentation, there is
no direct support for exactly this controller.
The controller is fairly simple, and understands plain ASCII / Byte
commands send via serial port, so i am pretty sure it is very similar to
other controllers which actually are supported.
But how do i proceed now ?
Is there some kind of general interface, where i can just define the
needed commands to make the motor record work with this controller ?
Or do i have to program a full new driver (starting maybe with one of
the existing ones) ?
The documentation (i found so far) regarding setting up a controller
with motor record is really sparse.
I am not an EPICS expert, but have done some projects with epics before.
In particular i am running another similar scanning table, where i did
the complete control (for a much simpler controller) only using
streamdevice and interconnecting records. But i guess, using the
particular stepmotor records is a more elegant way to go ???
In the documentation of motor record, it says: "The following
controllers are supported IN ADDIDION TO SOFT CHANNEL SUPPORT".
What is meant with this ?
Any help or advice (including links to some more detailed how-to
documentation) is very welcome !
Best regards,
Christian
- RE: using motor / steppermotor record for Trinamic TMCM-351 controller Mark Rivers
- Re: using motor / steppermotor record for Trinamic TMCM-351 controller Ron Sluiter
Re: Stepper Motor Controllers Torsten Bögershausen
Re: how NOT to update the record Ralph Lange
<2015>
2025
2026
Re: Conversion to Hexadecimal Rod Nussbaumer
<2015>
2025
2026
ANJ, 16 Dec 2015 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
