1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Stepper Motor Controllers
To: Torsten Bögershausen <[email protected]>
Cc: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 15 Jul 2015 14:05:40 +0000
>> Regarding closed loop mode:  While I can imagine circumstances where you might
>> want to disable it, I would think that any controller that supports an encoder
>> would also provide a closed loop mode.  Is that not so?  I would think there
>> would be little advantage to supporting an encoder if it couldn't be used
>> directly by the controller during movements (i.e. isn't this question the SAME
>> as "Does it support a position encoder"?)
> I think so.
> Some controllers should be able to make "smooth movements" towards the
> target position.
Just to clarify this point. The Parker 6K series does support encoders, but not closed loop control on stepper axes. It's only for feedback to the user. For some stages where the mechanics are poor, or we lose steps, we have to use the motor record retry capability. It's best to have the controller do the closed loop, so it can move to position, or fail, without having software logic on top.
Cheers,
Matt
RE: Stepper Motor Controllers Mark Rivers
Stepper Motor Controllers Mark Davis
Re: Stepper Motor Controllers Mark Davis
Re: Stepper Motor Controllers Torsten Bögershausen
Prev: RE: using motor / steppermotor record for Trinamic TMCM-351 controller Mark Rivers
Next: Linux vs. RTOS: cost and security; was: Stepper Motor Controllers Konrad, Martin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Stepper Motor Controllers Torsten Bögershausen
Next: RE: Stepper Motor Controllers Mark Rivers
