1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: MVME-5500 Universe II
Date: Wed, 29 Jul 2015 12:02:08 +0530
Hi All,
This is regarding the working of Tundra Universe II on VME based MVME-5500 CPU Board.
Three of the important signals on VMEbus are Address Strobe (AS*), Data Strobes (DS0* & DS1*) and Data Acknowledgement (DTACK*).
In a normal VMEbus data transfer cycle, the master asserts AS* and DS* signals. When a slave board responds with DTACK*, the master removes AS* and DS* and in turn slave also removes DTACK* thereby ending the cycle.
Two common types of addressing (for slave boards)are :
A16 (16-bit addressing) and
A24 (24-bit addressing).
On a MVME-5500 CPU,we have observed following three cases:
Case-1:
CPU runs under MOTload (native bootloader) and performs A24 cycle.
  1. CPU asserts AS* and DS* signals.
  2. Slave board responds with DTACK*
  3. CPU removes AS* and DS*
  4. In turn slave also removes DTACK* thereby ending the cycle.
Case-2:
CPU runs under vxWorks and performs A16 cycle.
  2. Slave board responds with DTACK*.
  3. CPU then removes AS* and DS*
Case-3:
CPU runs under vxWorks and performs A24 cycle.
  2. Slave board responds with DTACK*,
  3. CPU removes only DS* and not AS*. It expects the slave to remove DTACK*.
  4. Only on finding the DTACK* removed by slave, the master removes AS* ending the cycle.
Case-3  (A24, vxWorks) is the most used cycle type.
It is causing the problem as not every slave follows the sequence expected.
Some slave boards do not use DS* to derive DTACK*.  They derive DTACK* using AS* only.
In such cases CPU's AS* and Slave's DTACK* remain asserted causing a deadlock.
It seems the vxWorks BSP programs the Tundra Universe II chip for Case-3  in such a way that it behaves differently from Case-1 (MOTLoad) for A24 cycles.
Can we make any changes somewhere in vxWorks BSP or initialization-codes for Universe II so that CPU removes AS* when it finds DTACK* asserted by slave for A24 cycles also, which it is doing for A16 cycles .
Amit.
Re: MVME-5500 Universe II Michael Davidsaver
Prev: Re: Multi-threading in BOY Python scripts Kasemir, Kay
Next: Re: MVME-5500 Universe II Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Multi-threading in BOY Python scripts Williams Jr., Ernest L.
