1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MVME-5500 Universe II
To: [email protected]
Date: Wed, 29 Jul 2015 07:53:33 -0400
Hello Amit,
Many VME bus control lines (AS, DS*, and DTACK) are used for
asynchronous handshaking.  Sometimes the edge is important, and
sometimes the level.  The rules are complex.
Simply saying "A24" or "A16" isn't necessarily sufficient.  Giving the
exact address modifier in a good idea.  In this case I'm guessing its
0x39, 0x3A, 0x3D, or 0x3E.
I think you have a non-compliant slave card.  In my experience an
unfortunate, but not unusual, occurrence.  VME is more difficult to get
right than other parallel buses (ie PCI).  A VME master can't be
expected to accommodate a non-complaint slave card.
You should find a copy of the VME standard document.  If you can find
ANSI/VITA 1-1994 look for figure 2-8 "Non-multiplexed Address,
Single-Byte Read Cycle".
In particular, the following statement describes a clear violation of
the VME standard when applied to a single cycle read.
> Some slave boards do not use DS* to derive DTACK*.  They derive DTACK*
> using AS* only.
The following is a less clear violation.  My reading of the standard is
that the slave should not react to the AS* line going high.  In figure
2-8 the slave side flow includes "Receive AS* low", but never "Receive
AS* high".  The read is complete when the DS* lines are driven high.
>  1. CPU asserts AS* and DS* signals.
>  2. Slave board responds with DTACK*,
>  3. CPU removes only DS* and *not* AS*. It expects the slave to remove
>     DTACK*.
>  4. Only on finding the DTACK* removed by slave, the master removes AS*
>     ending the cycle.
In practice, after the slave asserts DTACK, I've seen VME masters
release AS and setup the address for the next operation.  I don't think
this is a question of master configuration, but rather of the time
between accesses.
Isn't VME fun :)
Michael
On 07/29/2015 02:32 AM, Amit Chauhan wrote:
> Hi All,
> This is regarding the working of Tundra Universe II on VME based
> MVME-5500 CPU Board.
> Three of the important signals on VMEbus are Address Strobe (AS*), Data
> Strobes (DS0* & DS1*) and Data Acknowledgement (DTACK*).
> In a normal VMEbus data transfer cycle, the master asserts AS* and DS*
> signals. When a slave board responds with DTACK*, the master removes AS*
> and DS* and in turn slave also removes DTACK* thereby ending the cycle.
> Two common types of addressing (for slave boards)are :
> *A16* (16-bit addressing) and
> *A24* (24-bit addressing).
> On a MVME-5500 CPU,we have observed following three cases:
> _*Case-1:*_
> CPU runs under *MOTload* (native bootloader) and performs *A24* cycle.
>  3. CPU removes AS* and DS*
>  4. In turn slave also removes DTACK* thereby ending the cycle.
> _*Case-2:*_
> CPU runs under *vxWorks* and performs *A16 *cycle.
>  2. Slave board responds with DTACK*.
>  3. CPU then removes AS* and DS*
> _*Case-3: *_
> CPU runs under *vxWorks* and performs *A24 *cycle.
>     DTACK*.
>     ending the cycle.
> Case-3  (A24, vxWorks) is the most used cycle type.
> It is causing the problem as not every slave follows the sequence expected.
> using AS* only.
> In such cases CPU's AS* and Slave's DTACK* remain asserted causing a
> deadlock.
> It seems the vxWorks BSP programs the Tundra Universe II chip for
> Case-3  in such a way that it behaves differently from Case-1 (MOTLoad)
> for A24 cycles.
> Can we make any changes somewhere in vxWorks BSP or initialization-codes
> for Universe II so that CPU removes AS* when it finds DTACK* asserted by
> slave for A24 cycles also, which it is doing for A16 cycles .
> Regards,
> Amit.
Re: MVME-5500 Universe II Amit Chauhan
Prev: MVME-5500 Universe II Amit Chauhan
Next: Passing a raw byte value from st.cmd to a StreamDevice proto file Michael Ritzert
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: MVME-5500 Universe II Amit Chauhan
