Hi all,
I have a VxWorks IOC (with MVME-CPU using both eth interfaces) communicating with a siemens S7PLC via Asyn/ModbusTCP.
EPICS release 3.14.12.4 Asyn v4.22
After a while (1 or 2 days), the communication is not working anymore ... but I have no error messages (no timeout nor
disconnection ...).
From IOC side I a have "Read Multiple Register" function reading the whole modbus table (109 registers) every second
and a "Write Multiple Register" function writing the value of a counter incremented every seconds from record level.
When I activate AsynTrace on IP Port or Read or Write ports there is no messages ...
asynReport on Read port indicates only 1 Read OK
asynReport on Write port indicates 0 Write OK
I can read the PLC register via "modpoll" tool from a Linux PC
I can start a Linux IOC connected to the same PLC
The netstat command on IOC shell tells that the TCP port is established but the Recv-Q is not equal to 0 (12 for example)
What can explain this behavior ?
thanks in advance !
Christophe Haquin
Control and Real Time systems Engineer
+33 231454661 office
+33 231454728 fax
SdA/GIM
GANIL
Bd Henri Becquerel BP 55027
14076 CAEN CEDEX5
begin:vcard
fn:Christophe Haquin
n:Haquin;Christophe
email;internet:[email protected]
tel;work:02 31 45 46 61
x-mozilla-html:FALSE
version:2.1
end:vcard
- RE: Asyn ModbusTCP communication KO without error messages Mark Rivers
Re: Virtual Circuit Disconnect Warning Andrew Johnson
<2015>
2025
2026
RE: Custom SQL data source for CSS Petro Kazmirchuk
<2015>
2025
2026
