On 09/04/2015 10:10 AM, Andrew Johnson wrote:
On 09/04/2015 11:12 AM, Till Straumann wrote:
You could do it with a bunch of calc (C1..C5, V) records
C1 computes (IN & 0xffff0000)
C2 computes (c1 ? c1 : IN ) & 0xff00ff00
C3 computes (c2 ? c2 : c1 ? c1 : IN) & 0xf0f0f0f0
C4 computes (c3 ? c3 : c2 ? c2 : c1 ? c1 : IN) & 0xcccccccc
C5 computes (c4 ? c4 : c3 ? c3 : c2 ? c2 : c1 ? c1 : IN) & 0xaaaaaaaa
V computes (C1 ? 16 : 0) + (C2 ? 8 : 0) + (C3 ? 4 : 0) + (C4 ? 2 : 0) +
(C5 ? 1 : 0)
If I've understood this code properly V will be the bit number of the
highest set bit, from 0 through 31. It doesn't distinguish between no
bits set and only the LSB set though, you'd have to detect that separately.
Yes - depends on what the result should be. I just intended to present
the idea.
The last line could e.g., be
IN ? (C1 ? 16 : 0) + (C2 ? 8 : 0) + (C3 ? 4 : 0) + (C4 ? 2 : 0) + (C5 ? 1 : 0) : -1
which would yield -1 if no bits are set.
The expressions could be simplified at the expense of more records
C1 = (IN & 0xffff0000)
C1C = C1 ? C1 : IN;
C2 = C1C & 0xff00ff00
C2C = C2 ? C2 : C1C
C3 = C2C & 0xf0f0f0f0
C3C = C3 ? C3 : C2C
C4 = C3C & 0xcccccccc
C4C = C4 ? C4 : C3C
C5 = C4C & 0xaaaaaaaa
If you have the synapps calc module installed a single transform record
could do all these calculations, transform handles up to 16 expressions.
You can find lots of bit-manipulation hacks at
https://graphics.stanford.edu/~seander/bithacks.html
- Andrew
On 09/04/2015 07:59 AM, Dudley, David wrote:
Quick question that I didn’t see an immediate way to perform
How do I select the most-significant set bit in an integer? I was
thinking about using a SEL, but that seems like a lot of work just to
do a simple thing. Other possibility would be a SUB, but I’d like to
do it with base record types if I can.
Something simple please…
- Select MS Bit from an integer Dudley, David
- Re: Select MS Bit from an integer Till Straumann
- Re: Select MS Bit from an integer Andrew Johnson
Spellman's Bertan 225 HV power supply James Rezende Piton
OT: EPICS, Beer, and International Travel Ryan Pierce
<2015>
2025
2026
RE: Select MS Bit from an integer Mooney, Tim M.
<2015>
2025
2026
