1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: dxp-3-2 in windows7-x64
To: <[email protected]>
Date: Wed, 9 Sep 2015 11:52:14 +0800
Hello, everyone
Hi, Mr. Mark Rivers
Everything  is ok excepting dxp-3-2 when I built the base-3.14.12.4 and synApps-5-7 in windows7 pro (64Bit) with Visual Studio 2008 64bit compiler. The error messages of “make” command has been attached in this email.
I have set:
         CROSS_COMPILER_HOST_ARCHS=windows-x64
         CROSS_COMPILER_TARGET_ARCHS=windows-x64
Also set:
   Call “C:\Program Files\VS9.0\VC\vcvarsall.bat” x86_amd64
First, use the default Makefile in the dxp-3-2\dxpApp\src\. There are no errors, but no dxpApp.exe in the dxp-3-2\bin\windows-x64\.
Then, I delete these lines (below) in Makefile, and change to “PROD_IOC += dxpApp” or “PROD_IOC_WIN32 += dxpApp”.
# build an ioc application
# tmm: for support only (no example), disable the App
PROD_IOC_vxWorks += dxpApp
ifeq ($(LINUX_USB_INSTALLED), YES)
PROD_IOC_Linux += dxpApp
endif
PROD_IOC_cygwin32 += dxpApp
ifeq (win32-x86, $(findstring win32-x86, $(T_A)))
Endif
Now, Open “Visual Studio 2008 x64 Cross Tools Command Prompt” and run the win32.bat in this DOS window.
Finaly, rebuild dxp-3-2 but failed due to the errors in the attached file. It seems something wrong in xia_epp.c and xia_plx.c. Please help!
By the way, I have successfully installed and applied the dxp-3-2 in windows7 x86-32 on Vortex hardware last year.
LIU Ping
Beamline Contrl Group, SSRF
No. 239 Zhangheng Road, Pudong, Shanghai
make: Entering directory `C:/epics/synApps_5_7/support/dxp-3-2'
make -C ./configure install
make[1]: Entering directory `C:/epics/synApps_5_7/support/dxp-3-2/configure'
perl C:/epics/base-3.14.12.4/bin/windows-x64/makeMakefile.pl O.windows-x64 ../..
perl -MExtUtils::Command -e mkpath O.Common
make -C O.windows-x64 -f ../Makefile TOP=../.. T_A=windows-x64 install
make[2]: Entering directory `C:/epics/synApps_5_7/support/dxp-3-2/configure/O.windows-x64'
perl C:/epics/base-3.14.12.4/bin/windows-x64/convertRelease.pl checkRelease
make[2]: Leaving directory `C:/epics/synApps_5_7/support/dxp-3-2/configure/O.windows-x64'
make[1]: Leaving directory `C:/epics/synApps_5_7/support/dxp-3-2/configure'
make -C ./dxpApp install
make[1]: Entering directory `C:/epics/synApps_5_7/support/dxp-3-2/dxpApp'
make -C ./handelSrc install
make[2]: Entering directory `C:/epics/synApps_5_7/support/dxp-3-2/dxpApp/handelSrc'
perl C:/epics/base-3.14.12.4/bin/windows-x64/makeMakefile.pl O.windows-x64 ../../..
make -C O.windows-x64 -f ../Makefile TOP=../../.. T_A=windows-x64 install
make[3]: Entering directory `C:/epics/synApps_5_7/support/dxp-3-2/dxpApp/handelSrc/O.windows-x64'
cl -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355     -DEXCLUDE_UDXP -DEXCLUDE_UDXPS -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DXIA_STATIC_BUILD -DEXCLUDE_CAMAC -DEXCLUDE_DXP4C2X -DHANDEL_USE_DLL -DHANDEL_MAKE_DLL -DWIN32   /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IC:\\epics\\synApps_5_7\\support\\seq-2-1-13\\include  -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include  -IC:\\epics\\synApps_5_7\\support\\camac-2-7\\include  -IC:\\epics\\synApps_5_7\\support\\dxp-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\calc-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\sscan-2-9\\include  -IC:\\epics\\synApps_5_7\\support\\busy-1-6\\include -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14.12.4\\include       ..\\xia_epp.c
xia_epp.c
cl -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355     -DEXCLUDE_UDXP -DEXCLUDE_UDXPS -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DXIA_STATIC_BUILD -DEXCLUDE_CAMAC -DEXCLUDE_DXP4C2X -DHANDEL_USE_DLL -DHANDEL_MAKE_DLL -DWIN32   /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IC:\\epics\\synApps_5_7\\support\\seq-2-1-13\\include  -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include  -IC:\\epics\\synApps_5_7\\support\\camac-2-7\\include  -IC:\\epics\\synApps_5_7\\support\\dxp-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\calc-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\sscan-2-9\\include  -IC:\\epics\\synApps_5_7\\support\\busy-1-6\\include -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14.12.4\\include       ..\\xia_plx.c
xia_plx.c
cl -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355     -DEXCLUDE_UDXP -DEXCLUDE_UDXPS -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DXIA_STATIC_BUILD -DEXCLUDE_CAMAC -DEXCLUDE_DXP4C2X -DHANDEL_USE_DLL -DHANDEL_MAKE_DLL -DWIN32   /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IC:\\epics\\synApps_5_7\\support\\seq-2-1-13\\include  -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include  -IC:\\epics\\synApps_5_7\\support\\camac-2-7\\include  -IC:\\epics\\synApps_5_7\\support\\dxp-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\calc-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\sscan-2-9\\include  -IC:\\epics\\synApps_5_7\\support\\busy-1-6\\include -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14.12.4\\include       ..\\xia_usb.c
xia_usb.c
cl -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355     -DEXCLUDE_UDXP -DEXCLUDE_UDXPS -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DXIA_STATIC_BUILD -DEXCLUDE_CAMAC -DEXCLUDE_DXP4C2X -DHANDEL_USE_DLL -DHANDEL_MAKE_DLL -DWIN32   /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IC:\\epics\\synApps_5_7\\support\\seq-2-1-13\\include  -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include  -IC:\\epics\\synApps_5_7\\support\\camac-2-7\\include  -IC:\\epics\\synApps_5_7\\support\\dxp-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\calc-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\sscan-2-9\\include  -IC:\\epics\\synApps_5_7\\support\\busy-1-6\\include -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14.12.4\\include       ..\\xia_usb2.c
xia_usb2.c
c:\epics\synapps_5_7\support\dxp-3-2\dxpapp\handelsrc\cyioctl.h(134) : warning C4005: 'METHOD_FROM_CTL_CODE' : macro redefinition
        C:\Program Files\Microsoft SDKs\Windows\v6.0A\include\winioctl.h(171) : see previous definition of 'METHOD_FROM_CTL_CODE'
..\xia_usb2.c(508) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
..\xia_usb2.c(528) : warning C4267: '=' : conversion from 'size_t' to 'ULONG', possible loss of data
cl -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355     -DEXCLUDE_UDXP -DEXCLUDE_UDXPS -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DXIA_STATIC_BUILD -DEXCLUDE_CAMAC -DEXCLUDE_DXP4C2X -DHANDEL_USE_DLL -DHANDEL_MAKE_DLL -DWIN32   /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IC:\\epics\\synApps_5_7\\support\\seq-2-1-13\\include  -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include  -IC:\\epics\\synApps_5_7\\support\\camac-2-7\\include  -IC:\\epics\\synApps_5_7\\support\\dxp-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\calc-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\sscan-2-9\\include  -IC:\\epics\\synApps_5_7\\support\\busy-1-6\\include -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14.12.4\\include       ..\\md_win32.c
md_win32.c
..\md_win32.c(1708) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
..\md_win32.c(1901) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
cl -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355     -DEXCLUDE_UDXP -DEXCLUDE_UDXPS -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DXIA_STATIC_BUILD -DEXCLUDE_CAMAC -DEXCLUDE_DXP4C2X -DHANDEL_USE_DLL -DHANDEL_MAKE_DLL -DWIN32   /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IC:\\epics\\synApps_5_7\\support\\seq-2-1-13\\include  -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include  -IC:\\epics\\synApps_5_7\\support\\camac-2-7\\include  -IC:\\epics\\synApps_5_7\\support\\dxp-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\calc-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\sscan-2-9\\include  -IC:\\epics\\synApps_5_7\\support\\busy-1-6\\include -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14.12.4\\include       ..\\xerxes.c
xerxes.c
..\xerxes.c(675) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
..\xerxes.c(681) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
..\xerxes.c(734) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
..\xerxes.c(812) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\xerxes.c(1452) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\xerxes.c(1463) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\xerxes.c(1479) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\xerxes.c(1492) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\xerxes.c(1508) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\xerxes.c(1528) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\xerxes.c(1564) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\xerxes.c(1619) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\xerxes.c(1621) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\xerxes.c(1638) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\xerxes.c(1648) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\xerxes.c(1650) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\xerxes.c(1669) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\xerxes.c(1679) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\xerxes.c(1681) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\xerxes.c(1748) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\xerxes.c(1750) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\xerxes.c(1767) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\xerxes.c(1769) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\xerxes.c(1791) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\xerxes.c(1793) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\xerxes.c(1914) : warning C4267: 'function' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\xerxes.c(1921) : warning C4267: 'function' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\xerxes.c(1978) : warning C4267: 'function' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\xerxes.c(2018) : warning C4267: 'function' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\xerxes.c(2032) : warning C4267: 'function' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\xerxes.c(2046) : warning C4267: 'function' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\xerxes.c(2060) : warning C4267: 'function' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\xerxes.c(2074) : warning C4267: 'function' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\xerxes.c(2112) : warning C4267: 'function' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\xerxes.c(2193) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\xerxes.c(3624) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\xerxes.c(3776) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\xerxes.c(3824) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\xerxes.c(6532) : warning C4267: 'function' : conversion from 'size_t' to 'unsigned int', possible loss of data
cl -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355     -DEXCLUDE_UDXP -DEXCLUDE_UDXPS -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DXIA_STATIC_BUILD -DEXCLUDE_CAMAC -DEXCLUDE_DXP4C2X -DHANDEL_USE_DLL -DHANDEL_MAKE_DLL -DWIN32   /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IC:\\epics\\synApps_5_7\\support\\seq-2-1-13\\include  -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include  -IC:\\epics\\synApps_5_7\\support\\camac-2-7\\include  -IC:\\epics\\synApps_5_7\\support\\dxp-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\calc-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\sscan-2-9\\include  -IC:\\epics\\synApps_5_7\\support\\busy-1-6\\include -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14.12.4\\include       ..\\xerxes_log.c
xerxes_log.c
cl -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355     -DEXCLUDE_UDXP -DEXCLUDE_UDXPS -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DXIA_STATIC_BUILD -DEXCLUDE_CAMAC -DEXCLUDE_DXP4C2X -DHANDEL_USE_DLL -DHANDEL_MAKE_DLL -DWIN32   /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IC:\\epics\\synApps_5_7\\support\\seq-2-1-13\\include  -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include  -IC:\\epics\\synApps_5_7\\support\\camac-2-7\\include  -IC:\\epics\\synApps_5_7\\support\\dxp-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\calc-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\sscan-2-9\\include  -IC:\\epics\\synApps_5_7\\support\\busy-1-6\\include -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14.12.4\\include       ..\\md_log.c
md_log.c
cl -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355     -DEXCLUDE_UDXP -DEXCLUDE_UDXPS -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DXIA_STATIC_BUILD -DEXCLUDE_CAMAC -DEXCLUDE_DXP4C2X -DHANDEL_USE_DLL -DHANDEL_MAKE_DLL -DWIN32   /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IC:\\epics\\synApps_5_7\\support\\seq-2-1-13\\include  -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include  -IC:\\epics\\synApps_5_7\\support\\camac-2-7\\include  -IC:\\epics\\synApps_5_7\\support\\dxp-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\calc-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\sscan-2-9\\include  -IC:\\epics\\synApps_5_7\\support\\busy-1-6\\include -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14.12.4\\include       ..\\handel.c
handel.c
cl -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355     -DEXCLUDE_UDXP -DEXCLUDE_UDXPS -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DXIA_STATIC_BUILD -DEXCLUDE_CAMAC -DEXCLUDE_DXP4C2X -DHANDEL_USE_DLL -DHANDEL_MAKE_DLL -DWIN32   /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IC:\\epics\\synApps_5_7\\support\\seq-2-1-13\\include  -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include  -IC:\\epics\\synApps_5_7\\support\\camac-2-7\\include  -IC:\\epics\\synApps_5_7\\support\\dxp-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\calc-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\sscan-2-9\\include  -IC:\\epics\\synApps_5_7\\support\\busy-1-6\\include -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14.12.4\\include       ..\\fdd.c
fdd.c
..\fdd.c(189) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
..\fdd.c(195) : warning C4018: '<' : signed/unsigned mismatch
..\fdd.c(210) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
..\fdd.c(274) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
..\fdd.c(529) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\fdd.c(548) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\fdd.c(571) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\fdd.c(583) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\fdd.c(607) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\fdd.c(634) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\fdd.c(1145) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
cl -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355     -DEXCLUDE_UDXP -DEXCLUDE_UDXPS -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DXIA_STATIC_BUILD -DEXCLUDE_CAMAC -DEXCLUDE_DXP4C2X -DHANDEL_USE_DLL -DHANDEL_MAKE_DLL -DWIN32   /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IC:\\epics\\synApps_5_7\\support\\seq-2-1-13\\include  -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include  -IC:\\epics\\synApps_5_7\\support\\camac-2-7\\include  -IC:\\epics\\synApps_5_7\\support\\dxp-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\calc-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\sscan-2-9\\include  -IC:\\epics\\synApps_5_7\\support\\busy-1-6\\include -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14.12.4\\include       ..\\psl.c
psl.c
cl -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355     -DEXCLUDE_UDXP -DEXCLUDE_UDXPS -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DXIA_STATIC_BUILD -DEXCLUDE_CAMAC -DEXCLUDE_DXP4C2X -DHANDEL_USE_DLL -DHANDEL_MAKE_DLL -DWIN32   /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IC:\\epics\\synApps_5_7\\support\\seq-2-1-13\\include  -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include  -IC:\\epics\\synApps_5_7\\support\\camac-2-7\\include  -IC:\\epics\\synApps_5_7\\support\\dxp-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\calc-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\sscan-2-9\\include  -IC:\\epics\\synApps_5_7\\support\\busy-1-6\\include -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14.12.4\\include       ..\\handel_dbg.c
handel_dbg.c
cl -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355     -DEXCLUDE_UDXP -DEXCLUDE_UDXPS -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DXIA_STATIC_BUILD -DEXCLUDE_CAMAC -DEXCLUDE_DXP4C2X -DHANDEL_USE_DLL -DHANDEL_MAKE_DLL -DWIN32   /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IC:\\epics\\synApps_5_7\\support\\seq-2-1-13\\include  -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include  -IC:\\epics\\synApps_5_7\\support\\camac-2-7\\include  -IC:\\epics\\synApps_5_7\\support\\dxp-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\calc-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\sscan-2-9\\include  -IC:\\epics\\synApps_5_7\\support\\busy-1-6\\include -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14.12.4\\include       ..\\handel_detchan.c
handel_detchan.c
cl -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355     -DEXCLUDE_UDXP -DEXCLUDE_UDXPS -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DXIA_STATIC_BUILD -DEXCLUDE_CAMAC -DEXCLUDE_DXP4C2X -DHANDEL_USE_DLL -DHANDEL_MAKE_DLL -DWIN32   /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IC:\\epics\\synApps_5_7\\support\\seq-2-1-13\\include  -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include  -IC:\\epics\\synApps_5_7\\support\\camac-2-7\\include  -IC:\\epics\\synApps_5_7\\support\\dxp-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\calc-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\sscan-2-9\\include  -IC:\\epics\\synApps_5_7\\support\\busy-1-6\\include -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14.12.4\\include       ..\\handel_dyn_default.c
cl -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355     -DEXCLUDE_UDXP -DEXCLUDE_UDXPS -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DXIA_STATIC_BUILD -DEXCLUDE_CAMAC -DEXCLUDE_DXP4C2X -DHANDEL_USE_DLL -DHANDEL_MAKE_DLL -DWIN32   /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IC:\\epics\\synApps_5_7\\support\\seq-2-1-13\\include  -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include  -IC:\\epics\\synApps_5_7\\support\\camac-2-7\\include  -IC:\\epics\\synApps_5_7\\support\\dxp-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\calc-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\sscan-2-9\\include  -IC:\\epics\\synApps_5_7\\support\\busy-1-6\\include -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14.12.4\\include       ..\\handel_dyn_detector.c
cl -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355     -DEXCLUDE_UDXP -DEXCLUDE_UDXPS -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DXIA_STATIC_BUILD -DEXCLUDE_CAMAC -DEXCLUDE_DXP4C2X -DHANDEL_USE_DLL -DHANDEL_MAKE_DLL -DWIN32   /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IC:\\epics\\synApps_5_7\\support\\seq-2-1-13\\include  -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include  -IC:\\epics\\synApps_5_7\\support\\camac-2-7\\include  -IC:\\epics\\synApps_5_7\\support\\dxp-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\calc-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\sscan-2-9\\include  -IC:\\epics\\synApps_5_7\\support\\busy-1-6\\include -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14.12.4\\include       ..\\handel_dyn_firmware.c
cl -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355     -DEXCLUDE_UDXP -DEXCLUDE_UDXPS -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DXIA_STATIC_BUILD -DEXCLUDE_CAMAC -DEXCLUDE_DXP4C2X -DHANDEL_USE_DLL -DHANDEL_MAKE_DLL -DWIN32   /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IC:\\epics\\synApps_5_7\\support\\seq-2-1-13\\include  -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include  -IC:\\epics\\synApps_5_7\\support\\camac-2-7\\include  -IC:\\epics\\synApps_5_7\\support\\dxp-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\calc-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\sscan-2-9\\include  -IC:\\epics\\synApps_5_7\\support\\busy-1-6\\include -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14.12.4\\include       ..\\handel_dyn_module.c
handel_dyn_module.c
cl -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355     -DEXCLUDE_UDXP -DEXCLUDE_UDXPS -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DXIA_STATIC_BUILD -DEXCLUDE_CAMAC -DEXCLUDE_DXP4C2X -DHANDEL_USE_DLL -DHANDEL_MAKE_DLL -DWIN32   /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IC:\\epics\\synApps_5_7\\support\\seq-2-1-13\\include  -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include  -IC:\\epics\\synApps_5_7\\support\\camac-2-7\\include  -IC:\\epics\\synApps_5_7\\support\\dxp-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\calc-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\sscan-2-9\\include  -IC:\\epics\\synApps_5_7\\support\\busy-1-6\\include -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14.12.4\\include       ..\\handel_file.c
handel_file.c
..\handel_file.c(677) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\handel_file.c(688) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\handel_file.c(703) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\handel_file.c(715) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\handel_file.c(731) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\handel_file.c(750) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
cl -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355     -DEXCLUDE_UDXP -DEXCLUDE_UDXPS -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DXIA_STATIC_BUILD -DEXCLUDE_CAMAC -DEXCLUDE_DXP4C2X -DHANDEL_USE_DLL -DHANDEL_MAKE_DLL -DWIN32   /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IC:\\epics\\synApps_5_7\\support\\seq-2-1-13\\include  -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include  -IC:\\epics\\synApps_5_7\\support\\camac-2-7\\include  -IC:\\epics\\synApps_5_7\\support\\dxp-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\calc-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\sscan-2-9\\include  -IC:\\epics\\synApps_5_7\\support\\busy-1-6\\include -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14.12.4\\include       ..\\handel_log.c
handel_log.c
cl -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355     -DEXCLUDE_UDXP -DEXCLUDE_UDXPS -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DXIA_STATIC_BUILD -DEXCLUDE_CAMAC -DEXCLUDE_DXP4C2X -DHANDEL_USE_DLL -DHANDEL_MAKE_DLL -DWIN32   /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IC:\\epics\\synApps_5_7\\support\\seq-2-1-13\\include  -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include  -IC:\\epics\\synApps_5_7\\support\\camac-2-7\\include  -IC:\\epics\\synApps_5_7\\support\\dxp-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\calc-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\sscan-2-9\\include  -IC:\\epics\\synApps_5_7\\support\\busy-1-6\\include -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14.12.4\\include       ..\\handel_memdbg_win32.c
cl -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355     -DEXCLUDE_UDXP -DEXCLUDE_UDXPS -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DXIA_STATIC_BUILD -DEXCLUDE_CAMAC -DEXCLUDE_DXP4C2X -DHANDEL_USE_DLL -DHANDEL_MAKE_DLL -DWIN32   /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IC:\\epics\\synApps_5_7\\support\\seq-2-1-13\\include  -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include  -IC:\\epics\\synApps_5_7\\support\\camac-2-7\\include  -IC:\\epics\\synApps_5_7\\support\\dxp-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\calc-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\sscan-2-9\\include  -IC:\\epics\\synApps_5_7\\support\\busy-1-6\\include -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14.12.4\\include       ..\\handel_run_control.c
cl -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355     -DEXCLUDE_UDXP -DEXCLUDE_UDXPS -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DXIA_STATIC_BUILD -DEXCLUDE_CAMAC -DEXCLUDE_DXP4C2X -DHANDEL_USE_DLL -DHANDEL_MAKE_DLL -DWIN32   /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IC:\\epics\\synApps_5_7\\support\\seq-2-1-13\\include  -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include  -IC:\\epics\\synApps_5_7\\support\\camac-2-7\\include  -IC:\\epics\\synApps_5_7\\support\\dxp-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\calc-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\sscan-2-9\\include  -IC:\\epics\\synApps_5_7\\support\\busy-1-6\\include -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14.12.4\\include       ..\\handel_run_params.c
handel_run_params.c
..\handel_run_params.c(1253) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
cl -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355     -DEXCLUDE_UDXP -DEXCLUDE_UDXPS -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DXIA_STATIC_BUILD -DEXCLUDE_CAMAC -DEXCLUDE_DXP4C2X -DHANDEL_USE_DLL -DHANDEL_MAKE_DLL -DWIN32   /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IC:\\epics\\synApps_5_7\\support\\seq-2-1-13\\include  -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include  -IC:\\epics\\synApps_5_7\\support\\camac-2-7\\include  -IC:\\epics\\synApps_5_7\\support\\dxp-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\calc-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\sscan-2-9\\include  -IC:\\epics\\synApps_5_7\\support\\busy-1-6\\include -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14.12.4\\include       ..\\handel_sort.c
handel_sort.c
cl -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355     -DEXCLUDE_UDXP -DEXCLUDE_UDXPS -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DXIA_STATIC_BUILD -DEXCLUDE_CAMAC -DEXCLUDE_DXP4C2X -DHANDEL_USE_DLL -DHANDEL_MAKE_DLL -DWIN32   /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IC:\\epics\\synApps_5_7\\support\\seq-2-1-13\\include  -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include  -IC:\\epics\\synApps_5_7\\support\\camac-2-7\\include  -IC:\\epics\\synApps_5_7\\support\\dxp-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\calc-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\sscan-2-9\\include  -IC:\\epics\\synApps_5_7\\support\\busy-1-6\\include -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14.12.4\\include       ..\\handel_system.c
handel_system.c
cl -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355     -DEXCLUDE_UDXP -DEXCLUDE_UDXPS -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DXIA_STATIC_BUILD -DEXCLUDE_CAMAC -DEXCLUDE_DXP4C2X -DHANDEL_USE_DLL -DHANDEL_MAKE_DLL -DWIN32   /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IC:\\epics\\synApps_5_7\\support\\seq-2-1-13\\include  -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include  -IC:\\epics\\synApps_5_7\\support\\camac-2-7\\include  -IC:\\epics\\synApps_5_7\\support\\dxp-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\calc-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\sscan-2-9\\include  -IC:\\epics\\synApps_5_7\\support\\busy-1-6\\include -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14.12.4\\include       ..\\handel_xerxes.c
handel_xerxes.c
..\handel_xerxes.c(1309) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
cl -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355     -DEXCLUDE_UDXP -DEXCLUDE_UDXPS -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DXIA_STATIC_BUILD -DEXCLUDE_CAMAC -DEXCLUDE_DXP4C2X -DHANDEL_USE_DLL -DHANDEL_MAKE_DLL -DWIN32   /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IC:\\epics\\synApps_5_7\\support\\seq-2-1-13\\include  -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include  -IC:\\epics\\synApps_5_7\\support\\camac-2-7\\include  -IC:\\epics\\synApps_5_7\\support\\dxp-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\calc-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\sscan-2-9\\include  -IC:\\epics\\synApps_5_7\\support\\busy-1-6\\include -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14.12.4\\include       ..\\xia_assert.c
xia_assert.c
cl -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355     -DEXCLUDE_UDXP -DEXCLUDE_UDXPS -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DXIA_STATIC_BUILD -DEXCLUDE_CAMAC -DEXCLUDE_DXP4C2X -DHANDEL_USE_DLL -DHANDEL_MAKE_DLL -DWIN32   /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IC:\\epics\\synApps_5_7\\support\\seq-2-1-13\\include  -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include  -IC:\\epics\\synApps_5_7\\support\\camac-2-7\\include  -IC:\\epics\\synApps_5_7\\support\\dxp-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\calc-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\sscan-2-9\\include  -IC:\\epics\\synApps_5_7\\support\\busy-1-6\\include -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14.12.4\\include       ..\\xia_file.c
xia_file.c
cl -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355     -DEXCLUDE_UDXP -DEXCLUDE_UDXPS -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DXIA_STATIC_BUILD -DEXCLUDE_CAMAC -DEXCLUDE_DXP4C2X -DHANDEL_USE_DLL -DHANDEL_MAKE_DLL -DWIN32   /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IC:\\epics\\synApps_5_7\\support\\seq-2-1-13\\include  -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include  -IC:\\epics\\synApps_5_7\\support\\camac-2-7\\include  -IC:\\epics\\synApps_5_7\\support\\dxp-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\calc-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\sscan-2-9\\include  -IC:\\epics\\synApps_5_7\\support\\busy-1-6\\include -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14.12.4\\include       ..\\xia_mem.c
xia_mem.c
cl -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355     -DEXCLUDE_UDXP -DEXCLUDE_UDXPS -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DXIA_STATIC_BUILD -DEXCLUDE_CAMAC -DEXCLUDE_DXP4C2X -DHANDEL_USE_DLL -DHANDEL_MAKE_DLL -DWIN32   /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IC:\\epics\\synApps_5_7\\support\\seq-2-1-13\\include  -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include  -IC:\\epics\\synApps_5_7\\support\\camac-2-7\\include  -IC:\\epics\\synApps_5_7\\support\\dxp-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\calc-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\sscan-2-9\\include  -IC:\\epics\\synApps_5_7\\support\\busy-1-6\\include -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14.12.4\\include       ..\\xia_mem_point.c
xia_mem_point.c
cl -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355     -DEXCLUDE_UDXP -DEXCLUDE_UDXPS -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DXIA_STATIC_BUILD -DEXCLUDE_CAMAC -DEXCLUDE_DXP4C2X -DHANDEL_USE_DLL -DHANDEL_MAKE_DLL -DWIN32   /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IC:\\epics\\synApps_5_7\\support\\seq-2-1-13\\include  -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include  -IC:\\epics\\synApps_5_7\\support\\camac-2-7\\include  -IC:\\epics\\synApps_5_7\\support\\dxp-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\calc-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\sscan-2-9\\include  -IC:\\epics\\synApps_5_7\\support\\busy-1-6\\include -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14.12.4\\include       ..\\saturn.c
saturn.c
..\saturn.c(1057) : warning C4267: '=' : conversion from 'size_t' to 'unsigned int', possible loss of data
..\saturn.c(1496) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
..\saturn.c(1582) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
cl -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355     -DEXCLUDE_UDXP -DEXCLUDE_UDXPS -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DXIA_STATIC_BUILD -DEXCLUDE_CAMAC -DEXCLUDE_DXP4C2X -DHANDEL_USE_DLL -DHANDEL_MAKE_DLL -DWIN32   /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IC:\\epics\\synApps_5_7\\support\\seq-2-1-13\\include  -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include  -IC:\\epics\\synApps_5_7\\support\\camac-2-7\\include  -IC:\\epics\\synApps_5_7\\support\\dxp-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\calc-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\sscan-2-9\\include  -IC:\\epics\\synApps_5_7\\support\\busy-1-6\\include -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14.12.4\\include       ..\\saturn_psl.c
saturn_psl.c
cl -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355     -DEXCLUDE_UDXP -DEXCLUDE_UDXPS -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DXIA_STATIC_BUILD -DEXCLUDE_CAMAC -DEXCLUDE_DXP4C2X -DHANDEL_USE_DLL -DHANDEL_MAKE_DLL -DWIN32   /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IC:\\epics\\synApps_5_7\\support\\seq-2-1-13\\include  -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include  -IC:\\epics\\synApps_5_7\\support\\camac-2-7\\include  -IC:\\epics\\synApps_5_7\\support\\dxp-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\calc-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\sscan-2-9\\include  -IC:\\epics\\synApps_5_7\\support\\busy-1-6\\include -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14.12.4\\include       ..\\xmap.c
xmap.c
..\xmap.c(469) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
..\xmap.c(764) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
cl -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355     -DEXCLUDE_UDXP -DEXCLUDE_UDXPS -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DXIA_STATIC_BUILD -DEXCLUDE_CAMAC -DEXCLUDE_DXP4C2X -DHANDEL_USE_DLL -DHANDEL_MAKE_DLL -DWIN32   /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IC:\\epics\\synApps_5_7\\support\\seq-2-1-13\\include  -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include  -IC:\\epics\\synApps_5_7\\support\\camac-2-7\\include  -IC:\\epics\\synApps_5_7\\support\\dxp-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\calc-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\sscan-2-9\\include  -IC:\\epics\\synApps_5_7\\support\\busy-1-6\\include -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14.12.4\\include       ..\\xmap_psl.c
xmap_psl.c
cl -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355     -DEXCLUDE_UDXP -DEXCLUDE_UDXPS -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DXIA_STATIC_BUILD -DEXCLUDE_CAMAC -DEXCLUDE_DXP4C2X -DHANDEL_USE_DLL -DHANDEL_MAKE_DLL -DWIN32   /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IC:\\epics\\synApps_5_7\\support\\seq-2-1-13\\include  -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include  -IC:\\epics\\synApps_5_7\\support\\camac-2-7\\include  -IC:\\epics\\synApps_5_7\\support\\dxp-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\calc-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\sscan-2-9\\include  -IC:\\epics\\synApps_5_7\\support\\busy-1-6\\include -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14.12.4\\include       ..\\mercury.c
mercury.c
..\mercury.c(389) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
..\mercury.c(630) : warning C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
cl -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355     -DEXCLUDE_UDXP -DEXCLUDE_UDXPS -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DXIA_STATIC_BUILD -DEXCLUDE_CAMAC -DEXCLUDE_DXP4C2X -DHANDEL_USE_DLL -DHANDEL_MAKE_DLL -DWIN32   /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IC:\\epics\\synApps_5_7\\support\\seq-2-1-13\\include  -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include  -IC:\\epics\\synApps_5_7\\support\\camac-2-7\\include  -IC:\\epics\\synApps_5_7\\support\\dxp-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\calc-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\sscan-2-9\\include  -IC:\\epics\\synApps_5_7\\support\\busy-1-6\\include -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14.12.4\\include       ..\\mercury_psl.c
mercury_psl.c
lib /nologo /verbose /out:handel.lib /LTCG       xia_epp.obj xia_plx.obj xia_usb.obj xia_usb2.obj md_win32.obj xerxes.obj xerxes_log.obj md_log.obj handel.obj fdd.obj psl.obj handel_dbg.obj handel_detchan.obj handel_dyn_default.obj handel_dyn_detector.obj handel_dyn_firmware.obj handel_dyn_module.obj handel_file.obj handel_log.obj handel_memdbg_win32.obj handel_run_control.obj handel_run_params.obj handel_sort.obj handel_system.obj handel_xerxes.obj xia_assert.obj xia_file.obj xia_mem.obj xia_mem_point.obj saturn.obj saturn_psl.obj xmap.obj xmap_psl.obj mercury.obj mercury_psl.obj
Appending mercury_psl.obj
Appending mercury.obj
Appending xmap_psl.obj
Appending xmap.obj
Appending saturn_psl.obj
Appending saturn.obj
Appending xia_mem_point.obj
Appending xia_mem.obj
Appending xia_file.obj
Appending xia_assert.obj
Appending handel_xerxes.obj
Appending handel_system.obj
Appending handel_sort.obj
Appending handel_run_params.obj
Appending handel_run_control.obj
Appending handel_memdbg_win32.obj
Appending handel_log.obj
Appending handel_file.obj
Appending handel_dyn_module.obj
Appending handel_dyn_firmware.obj
Appending handel_dyn_detector.obj
Appending handel_dyn_default.obj
Appending handel_detchan.obj
Appending handel_dbg.obj
Appending psl.obj
Appending fdd.obj
Appending handel.obj
Appending md_log.obj
Appending xerxes_log.obj
Appending xerxes.obj
Appending md_win32.obj
Appending xia_usb2.obj
Appending xia_usb.obj
Appending xia_plx.obj
Appending xia_epp.obj
"Installing library ../../../lib/windows-x64/handel.lib"
make[3]: Leaving directory `C:/epics/synApps_5_7/support/dxp-3-2/dxpApp/handelSrc/O.windows-x64'
make[2]: Leaving directory `C:/epics/synApps_5_7/support/dxp-3-2/dxpApp/handelSrc'
make -C ./src install
make[2]: Entering directory `C:/epics/synApps_5_7/support/dxp-3-2/dxpApp/src'
make[3]: Entering directory `C:/epics/synApps_5_7/support/dxp-3-2/dxpApp/src/O.windows-x64'
echo "../O.Common/dxp.dbd : ../Makefile" >> dxp.dbd.d
"Expanding dbd"
C:\\epics\\base-3.14.12.4\\bin\\windows-x64\\dbExpand.exe  -I. -I.. -I../O.Common -I../../../dbd -IC:/epics/synApps_5_7/support/seq-2-1-13/dbd -IC:/epics/synApps_5_7/support/asyn-4-21/dbd -IC:/epics/synApps_5_7/support/areaDetector-1-9-1/dbd -IC:/epics/synApps_5_7/support/mca-7-4/dbd -IC:/epics/synApps_5_7/support/camac-2-7/dbd -IC:/epics/synApps_5_7/support/dxp-3-2/dbd -IC:/epics/synApps_5_7/support/calc-3-2/dbd -IC:/epics/synApps_5_7/support/sscan-2-9/dbd -IC:/epics/synApps_5_7/support/busy-1-6/dbd -IC:/epics/synApps_5_7/support/autosave-5-1/dbd -IC:/epics/base-3.14.12.4/dbd -o dxp.dbd ../dxpInclude.dbd
echo "../O.Common/dxpVX.dbd : ../Makefile" >> dxpVX.dbd.d
"Expanding dbd"
C:\\epics\\base-3.14.12.4\\bin\\windows-x64\\dbExpand.exe  -I. -I.. -I../O.Common -I../../../dbd -IC:/epics/synApps_5_7/support/seq-2-1-13/dbd -IC:/epics/synApps_5_7/support/asyn-4-21/dbd -IC:/epics/synApps_5_7/support/areaDetector-1-9-1/dbd -IC:/epics/synApps_5_7/support/mca-7-4/dbd -IC:/epics/synApps_5_7/support/camac-2-7/dbd -IC:/epics/synApps_5_7/support/dxp-3-2/dbd -IC:/epics/synApps_5_7/support/calc-3-2/dbd -IC:/epics/synApps_5_7/support/sscan-2-9/dbd -IC:/epics/synApps_5_7/support/busy-1-6/dbd -IC:/epics/synApps_5_7/support/autosave-5-1/dbd -IC:/epics/base-3.14.12.4/dbd -o dxpVX.dbd ../dxpVXInclude.dbd
"Installing created dbd file ../../../dbd/dxp.dbd"
"Installing created dbd file ../../../dbd/dxpVX.dbd"
cl /nologo /EHsc /GR -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO /TP   -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IC:\\epics\\synApps_5_7\\support\\seq-2-1-13\\include  -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include  -IC:\\epics\\synApps_5_7\\support\\camac-2-7\\include  -IC:\\epics\\synApps_5_7\\support\\dxp-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\calc-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\sscan-2-9\\include  -IC:\\epics\\synApps_5_7\\support\\busy-1-6\\include -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14.12.4\\include       ..\\NDDxp.cpp
NDDxp.cpp
..\NDDxp.cpp(463) : warning C4244: 'argument' : conversion from '__int64' to 'int', possible loss of data
"preprocessing ../dxpMED.st"
cl /C /E             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE -I. -I../O.Common -I. -I.. -I../../../include/os/WIN32 -I../../../include    -IC:/epics/synApps_5_7/support/seq-2-1-13/include  -IC:/epics/synApps_5_7/support/asyn-4-21/include -IC:/epics/synApps_5_7/support/areaDetector-1-9-1/include/os/WIN32 -IC:/epics/synApps_5_7/support/areaDetector-1-9-1/include -IC:/epics/synApps_5_7/support/mca-7-4/include/os/WIN32 -IC:/epics/synApps_5_7/support/mca-7-4/include  -IC:/epics/synApps_5_7/support/camac-2-7/include  -IC:/epics/synApps_5_7/support/dxp-3-2/include  -IC:/epics/synApps_5_7/support/calc-3-2/include  -IC:/epics/synApps_5_7/support/sscan-2-9/include  -IC:/epics/synApps_5_7/support/busy-1-6/include -IC:/epics/synApps_5_7/support/autosave-5-1/include/os/WIN32 -IC:/epics/synApps_5_7/support/autosave-5-1/include -IC:/epics/base-3.14.12.4/include/os/WIN32 -IC:/epics/base-3.14.12.4/include       ../dxpMED.st > dxpMED.i
"converting dxpMED.i"
C:/epics/synApps_5_7/support/seq-2-1-13/bin/windows-x64/snc.exe     dxpMED.i -o dxpMED.c.tmp
perl -MExtUtils::Command -e mv dxpMED.c.tmp dxpMED.c
cl -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355     -DXIA_SPECIAL_MEM -DEXCLUDE_DGFG200 -DEXCLUDE_UDXPS   /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IC:\\epics\\synApps_5_7\\support\\seq-2-1-13\\include  -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include  -IC:\\epics\\synApps_5_7\\support\\camac-2-7\\include  -IC:\\epics\\synApps_5_7\\support\\dxp-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\calc-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\sscan-2-9\\include  -IC:\\epics\\synApps_5_7\\support\\busy-1-6\\include -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14.12.4\\include       dxpMED.c
dxpMED.c
../dxpMED.st(1532) : warning C4244: '=' : conversion from 'double' to 'int', possible loss of data
../dxpMED.st(1538) : warning C4244: '=' : conversion from 'double' to 'int', possible loss of data
lib /nologo /verbose /out:dxp.lib /LTCG       NDDxp.obj dxpMED.obj
Appending dxpMED.obj
Appending NDDxp.obj
"Installing library ../../../lib/windows-x64/dxp.lib"
cl /nologo /EHsc /GR -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO /TP   -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IC:\\epics\\synApps_5_7\\support\\seq-2-1-13\\include  -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include  -IC:\\epics\\synApps_5_7\\support\\camac-2-7\\include  -IC:\\epics\\synApps_5_7\\support\\dxp-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\calc-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\sscan-2-9\\include  -IC:\\epics\\synApps_5_7\\support\\busy-1-6\\include -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14.12.4\\include       ..\\dxpMain.cpp
dxpMain.cpp
perl C:/epics/base-3.14.12.4/bin/windows-x64/registerRecordDeviceDriver.pl ../O.Common/dxp.dbd dxp_registerRecordDeviceDriver C:/epics/synApps_5_7/support/dxp-3-2 > dxp.tmp
perl -MExtUtils::Command -e mv dxp.tmp dxp_registerRecordDeviceDriver.cpp
cl /nologo /EHsc /GR -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO /TP   -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include    -IC:\\epics\\synApps_5_7\\support\\seq-2-1-13\\include  -IC:\\epics\\synApps_5_7\\support\\asyn-4-21\\include -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\include -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\mca-7-4\\include  -IC:\\epics\\synApps_5_7\\support\\camac-2-7\\include  -IC:\\epics\\synApps_5_7\\support\\dxp-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\calc-3-2\\include  -IC:\\epics\\synApps_5_7\\support\\sscan-2-9\\include  -IC:\\epics\\synApps_5_7\\support\\busy-1-6\\include -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\epics\\synApps_5_7\\support\\autosave-5-1\\include -IC:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\epics\\base-3.14.12.4\\include       dxp_registerRecordDeviceDriver.cpp
link -nologo  /LTCG /incremental:no /opt:ref /release   /MACHINE:X64    /NODEFAULTLIB:MSVCRT.lib          -out:dxpApp.exe        dxpMain.obj dxp_registerRecordDeviceDriver.obj     ..\\..\\..\\lib\\windows-x64\\dxp.lib  ..\\..\\..\\lib\\windows-x64\\handel.lib  C:\\epics\\synApps_5_7\\support\\mca-7-4\\lib\\windows-x64\\mca.lib  C:\\epics\\synApps_5_7\\support\\asyn-4-21\\lib\\windows-x64\\asyn.lib  C:\\epics\\synApps_5_7\\support\\calc-3-2\\lib\\windows-x64\\calc.lib  C:\\epics\\synApps_5_7\\support\\sscan-2-9\\lib\\windows-x64\\sscan.lib  C:\\epics\\synApps_5_7\\support\\autosave-5-1\\lib\\windows-x64\\autosave.lib  C:\\epics\\synApps_5_7\\support\\busy-1-6\\lib\\windows-x64\\busy.lib  C:\\epics\\synApps_5_7\\support\\seq-2-1-13\\lib\\windows-x64\\seq.lib  C:\\epics\\synApps_5_7\\support\\seq-2-1-13\\lib\\windows-x64\\pv.lib  C:\\epics\\base-3.14.12.4\\lib\\windows-x64\\recIoc.lib  C:\\epics\\base-3.14.12.4\\lib\\windows-x64\\softDevIoc.lib  C:\\epics\\base-3.14.12.4\\lib\\windows-x64\\miscIoc.lib  C:\\epics\\base-3.14.12.4\\lib\\windows-x64\\rsrvIoc.lib  C:\\epics\\base-3.14.12.4\\lib\\windows-x64\\dbtoolsIoc.lib  C:\\epics\\base-3.14.12.4\\lib\\windows-x64\\asIoc.lib  C:\\epics\\base-3.14.12.4\\lib\\windows-x64\\dbIoc.lib  C:\\epics\\base-3.14.12.4\\lib\\windows-x64\\registryIoc.lib  C:\\epics\\base-3.14.12.4\\lib\\windows-x64\\dbStaticIoc.lib  C:\\epics\\base-3.14.12.4\\lib\\windows-x64\\ca.lib  C:\\epics\\base-3.14.12.4\\lib\\windows-x64\\Com.lib  ..\\..\\..\\lib\\windows-x64\\DLPORTIO.lib  ..\\..\\..\\lib\\windows-x64\\PlxApi.lib  C:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\lib\\windows-x64\\NDPlugin.lib  C:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\lib\\windows-x64\\ADBase.lib  C:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\lib\\windows-x64\\netCDF.lib  C:\\epics\\synApps_5_7\\support\\calc-3-2\\lib\\windows-x64\\calc.lib  C:\\epics\\synApps_5_7\\support\\busy-1-6\\lib\\windows-x64\\busy.lib  C:\\epics\\synApps_5_7\\support\\sscan-2-9\\lib\\windows-x64\\sscan.lib  C:\\epics\\synApps_5_7\\support\\autosave-5-1\\lib\\windows-x64\\autosave.lib  C:\\epics\\synApps_5_7\\support\\asyn-4-21\\lib\\windows-x64\\asyn.lib  C:\\epics\\base-3.14.12.4\\lib\\windows-x64\\recIoc.lib  C:\\epics\\base-3.14.12.4\\lib\\windows-x64\\softDevIoc.lib  C:\\epics\\base-3.14.12.4\\lib\\windows-x64\\miscIoc.lib  C:\\epics\\base-3.14.12.4\\lib\\windows-x64\\rsrvIoc.lib  C:\\epics\\base-3.14.12.4\\lib\\windows-x64\\dbtoolsIoc.lib  C:\\epics\\base-3.14.12.4\\lib\\windows-x64\\asIoc.lib  C:\\epics\\base-3.14.12.4\\lib\\windows-x64\\dbIoc.lib  C:\\epics\\base-3.14.12.4\\lib\\windows-x64\\registryIoc.lib  C:\\epics\\base-3.14.12.4\\lib\\windows-x64\\dbStaticIoc.lib  C:\\epics\\base-3.14.12.4\\lib\\windows-x64\\ca.lib  C:\\epics\\base-3.14.12.4\\lib\\windows-x64\\Com.lib  C:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\lib\\windows-x64\\tiff.lib  C:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\lib\\windows-x64\\jpeg.lib  C:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\lib\\windows-x64\\PvAPI.lib  C:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\lib\\windows-x64\\NeXus.lib  C:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\lib\\windows-x64\\hdf5.lib  C:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\lib\\windows-x64\\libszip.lib  C:\\epics\\synApps_5_7\\support\\areaDetector-1-9-1\\lib\\windows-x64\\zlib.lib setupapi.lib Gdi32.lib Oleaut32.lib ws2_32.lib advapi32.lib user32.lib kernel32.lib winmm.lib
   Creating library dxpApp.lib and object dxpApp.exp
handel.lib(xia_epp.obj) : error LNK2001: unresolved external symbol DlPortReadPortBufferUlong
handel.lib(xia_epp.obj) : error LNK2001: unresolved external symbol DlPortWritePortUchar
handel.lib(xia_epp.obj) : error LNK2001: unresolved external symbol DlPortReadPortBufferUshort
handel.lib(xia_epp.obj) : error LNK2001: unresolved external symbol DlPortReadPortUchar
handel.lib(xia_epp.obj) : error LNK2001: unresolved external symbol DlPortWritePortBufferUshort
handel.lib(xia_plx.obj) : error LNK2001: unresolved external symbol PlxPci_DmaTransferUserBuffer
handel.lib(xia_plx.obj) : error LNK2001: unresolved external symbol PlxPci_DeviceOpen
handel.lib(xia_plx.obj) : error LNK2001: unresolved external symbol PlxPci_DmaChannelClose
handel.lib(xia_plx.obj) : error LNK2001: unresolved external symbol PlxPci_PciBarMap
handel.lib(xia_plx.obj) : error LNK2001: unresolved external symbol PlxPci_NotificationWait
handel.lib(xia_plx.obj) : error LNK2001: unresolved external symbol PlxPci_NotificationRegisterFor
handel.lib(xia_plx.obj) : error LNK2001: unresolved external symbol PlxPci_DeviceClose
handel.lib(xia_plx.obj) : error LNK2001: unresolved external symbol PlxPci_PciBarUnmap
handel.lib(xia_plx.obj) : error LNK2001: unresolved external symbol PlxPci_DmaChannelOpen
dxpApp.exe : fatal error LNK1120: 14 unresolved externals
make[3]: Leaving directory `C:/epics/synApps_5_7/support/dxp-3-2/dxpApp/src/O.windows-x64'
make[2]: Leaving directory `C:/epics/synApps_5_7/support/dxp-3-2/dxpApp/src'
make[1]: Leaving directory `C:/epics/synApps_5_7/support/dxp-3-2/dxpApp'
make: Leaving directory `C:/epics/synApps_5_7/support/dxp-3-2'
RE: dxp-3-2 in windows7-x64 Mark Rivers
Prev: Re: building labCA on base 3.15.2, missing tsDefs.h Till Straumann
Next: RE: dxp-3-2 in windows7-x64 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: AW: CSS - Permission denied error info22
