1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: dxp-3-2 in windows7-x64
To: "'LiuP'" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 9 Sep 2015 14:57:55 +0000
Hi Liu Ping,
The problem is that you are building for the windows-x64 architecture.  That is not supported, the XIA drivers and Handel library currently only support 32-bit architectures on both Windows and Linux.  You should build for the win32-x86 architecture instead.  The documentation (http://cars9.uchicago.edu/software/epics/dxpDoc.html) states that the only supported architectures are win32-x86 and cygwin-x86.
From: [email protected] [mailto:[email protected]] On Behalf Of LiuP
Sent: Tuesday, September 08, 2015 10:52 PM
To: [email protected]
Subject: dxp-3-2 in windows7-x64
Hello, everyone
Hi, Mr. Mark Rivers
Everything  is ok excepting dxp-3-2 when I built the base-3.14.12.4 and synApps-5-7 in windows7 pro (64Bit) with Visual Studio 2008 64bit compiler. The error messages of “make” command has been attached in this email.
I have set:
         CROSS_COMPILER_HOST_ARCHS=windows-x64
         CROSS_COMPILER_TARGET_ARCHS=windows-x64
Also set:
   Call “C:\Program Files\VS9.0\VC\vcvarsall.bat” x86_amd64
First, use the default Makefile in the dxp-3-2\dxpApp\src\. There are no errors, but no dxpApp.exe in the dxp-3-2\bin\windows-x64\.
Then, I delete these lines (below) in Makefile, and change to “PROD_IOC += dxpApp” or “PROD_IOC_WIN32 += dxpApp”.
# build an ioc application
# tmm: for support only (no example), disable the App
PROD_IOC_vxWorks += dxpApp
ifeq ($(LINUX_USB_INSTALLED), YES)
PROD_IOC_Linux += dxpApp
endif
PROD_IOC_cygwin32 += dxpApp
ifeq (win32-x86, $(findstring win32-x86, $(T_A)))
Endif
Now, Open “Visual Studio 2008 x64 Cross Tools Command Prompt” and run the win32.bat in this DOS window.
Finaly, rebuild dxp-3-2 but failed due to the errors in the attached file. It seems something wrong in xia_epp.c and xia_plx.c. Please help!
By the way, I have successfully installed and applied the dxp-3-2 in windows7 x86-32 on Vortex hardware last year.
LIU Ping
Beamline Contrl Group, SSRF
No. 239 Zhangheng Road, Pudong, Shanghai
dxp-3-2 in windows7-x64 LiuP
Prev: dxp-3-2 in windows7-x64 LiuP
Next: RE: Asyn ModbusTCP communication KO without error messages Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: SetVoltage problem info22
