1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: SetVoltage problem
To: EPICS Tech-Talk <[email protected]>
Date: Thu, 10 Sep 2015 09:35:30 +0200
Hello,
the first record waits for user value. The second reads the value back. The seconde increase or decrease it and hold the value.
User Value: 10 V
Calc: 0, 1, 2, .... 10
My Problem:  Let's say the current value (hardware device) is 8 V. If I I restart the IOC and put a new value like 10V i want to continiou ti increase 8, 9, 10V. But The after restarting the IOC my first Calc-Value is 0.
Current Value: 8V
SetVolt: 10V
Calc: 0, 1, 2, 3, 4 ... 10.
Is there other possibility? And my second problem is I want to make a seq-record to increase after 30, 60 and 90 seconds.
For example (epics and css):
User Volt Selection: 1000V, 1500V and 2000V
User Slew Rate Option: 5V, 10V, 15V / per Time
Time: 30 seconds, 60 seconds, 90 seconds
record(ao, "SetVolt") {
field(EGU, “V”)
field(LOPR, “0”)
field(HOPR, “28”)
field(DRVH, “28”)
field(DRVL, “0”)
field(VAL, “0”)
record(ai, "SetVoltReadback"){
field(DTYP, “stream”)
field(INP, "@xyz.proto read($(xyz)) $(device)")
field(SCAN, “1 second”)
field(FLNK, "VoltCalc PP")
record(calcout, "VoltCalc") {
field(DESC, “Write Voltag Out”)
field(CALC, "A:= ((C<(A-B)) ? (A-B) : ((A+B)>C ? C : (A+B)));A")
field(INPA, "VoltCalc.VAL")
field(INPB, “SlewRate”) /* standard:1 */
field(INPC, "SetVolt")
field(OUT, "WriteOut.VAL PP")
field(OOPT, “On Change”)
field(DOPT, “Use CALC”)
RE: SetVoltage problem Arnold, Ned D.
Re: SetVoltage problem Pearson, Matthew R.
Prev: RE: building labCA on base 3.15.2, missing tsDefs.h Gierman, Stephen
Next: RE: SetVoltage problem Arnold, Ned D.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: dxp-3-2 in windows7-x64 Mark Rivers
