Till,
lcaGetEnumStrings IS working for me in matlab; I don't know why I had problems yesterday. It's a nice feature -- thanks.
>> lcaGet('LTD-Q1D:Control')
Initializing labCA Release '$Name: labca_3_5_0 $'...
Author: Till Straumann <[email protected]>
ans =
'DONE'
>> lcaGetEnumStrings('LTD-Q1D:Control')
ans =
'DONE' 'RAMPOFF' 'RAMPON' 'RAMPDES' 'STANDARDIZE' 'RAMPZERO' 'RAMPMIN' 'RAMPRESTORE' '' '' '' '' '' '' '' ''
Steve
-----Original Message-----
Sent: Tuesday, September 08, 2015 8:09 PM
To: Gierman, Stephen; '[email protected]'
Subject: Re: building labCA on base 3.15.2, missing tsDefs.h
On 09/08/2015 02:43 PM, Gierman, Stephen wrote:
> Hi Till,
> Thanks for labCA-3.5.0. I've built and tested it on windows-x64 and it mostly seems to be working. I get an odd message when I build:
> C:\epics\R3.15.2\extensions\src\labca_3_5_0>make >
> make_labca_3_5_0.txt
> process_begin: CreateProcess(NULL, sed -n -e "s/\(.*[^b]subsection.*[{][ \t]*\)\(lca[a-zA-Z0-9]*\).*/\2/gp" manual.tex, ...) failed.
Thanks. That's luckily benign (safe to ignore) but nevertheless a bug in the makefile. The above command should not have to be executed unless documentation is rebuilt from the .tex file. I usually create docs during the release process so there is no need for 'sed' -- which may not be available under windows.
> And I may have a problem with the new lcaGetEnumStrings(). Here's what happens in matlab R2015a:
> Invalid MEX-file
> 'C:\epics\R3.15.2\extensions\src\labca_3_5_0\bin\windows-x64\labca\lcaGetEnumStrings.mexw64': The specified procedure could not be found.
Hmm - I'm not able to reproduce this. Works fine for me -- but the only matlab I have access to is
2012a/linux-x86 and 2014b/linux-x86_64.
Do the other entry points work (e.g., 'lcaGet()') ?
- Till
> Steve
> From: Till Straumann [mailto:[email protected]]
> Sent: Tuesday, September 08, 2015 12:56 PM
> Yeah. tsDefs is cruft from the old days.
> I just put up a new release (labca-3.5.0) which does away with tsDefs and TS_STAMP (replaced by epicsTime.h and epicsTimeStamp, respectively).
> This release also features a new call 'lcaGetEnumStrings()' which allows you to retrieve the set of possible values for enum-type PVs.
> Available as usual from
> http://www.slac.stanford.edu/~strauman/labca/
> - Till
> On 09/07/2015 03:23 PM, Gierman, Stephen wrote:
>> Hi,
>> I'm building labCA (version 3.4.2) on base-3.15.2 for 64-bit windows. The build fails in the 'glue' directory when it cannot find the include file 'tsDefs.h'. Indeed, I do not find tsDefs.h in base-3.15.2, but I do find it in base-3.14.12.2, though it seems to be deprecated there. Here are the last few lines of the build:
>> cl -EHsc -GR -DMATLAB_APP -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include -I../../../../../base/include/compiler/msvc -I../../../../../base/include/os/WIN32 -I../../../../../base/include -I../../ezca -IC:\matlab\R2015a/extern/include -c ../ini.cc
>> ini.cc
>> ..\multiEzca.h(32) : fatal error C1083: Cannot open include file:
>> 'tsDefs.h': No such file or directory
>> make[2]: Leaving directory `C:/epics/R3.15.2/extensions/src/labca_3_4_2/glue/O.windows-x64'
>> make[1]: Leaving directory `C:/epics/R3.15.2/extensions/src/labca_3_4_2/glue'
>> I'm not sure what to do next ...
>> Steve Gierman
- building labCA on base 3.15.2, missing tsDefs.h Gierman, Stephen
- Re: building labCA on base 3.15.2, missing tsDefs.h Till Straumann
- RE: building labCA on base 3.15.2, missing tsDefs.h Gierman, Stephen
RE: Asyn ModbusTCP communication KO without error messages Mark Rivers
SetVoltage problem info22
<2015>
2025
2026
store data to hard disk l123173
<2015>
2025
2026
