1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Unable to build support modules on Windows, with base 3.15.2
To: "'Heesterman, Peter J'" <[email protected]>, "'Jani Hakala'" <[email protected]>
Cc: "EPICS Tech-Talk \([email protected]\)" <[email protected]>
Date: Wed, 16 Sep 2015 18:20:45 +0000
No, I mean the Windows "set" command with no arguments so we can see the values of all environment variables when you run make.
-----Original Message-----
From: Heesterman, Peter J [mailto:[email protected]]
Sent: Wednesday, September 16, 2015 1:19 PM
To: Mark Rivers; 'Jani Hakala'
Cc: EPICS Tech-Talk ([email protected])
Hi Mark,
>> modified any of the files in base/configure/os?
No. I've checked carefully.
The RELEASE file is attached (as been fiddling with D:'s and slashes).
Which set are you referring to?
Do you mean setting the path to perl, called from win32.bat?
D:\EPICS>REM   --------------- ActiveState perl -------------------
D:\EPICS>set PATH=C:\Perl\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\SYSTEM32\Wbem
Cheers,
Peter.
Sent: 16 September 2015 18:54
To: Heesterman, Peter J; 'Jani Hakala'
Strange, it is putting the current path in front of the path to the perl script in base.
Have you modified any of the files in base/configure/os?
Send the contents of asyn/configure/RELEASE and the output of the "set" command.
Sent: Wednesday, September 16, 2015 12:21 PM
Hi Mark,
That's a combination that I've tried, with the result attached.
Cheers,
Peter.
Sent: 16 September 2015 17:45
I define EPICS_BASE like this:
EPICS_BASE=H:/epics/base-3.14.12.5
I use a drive letter and forward slashes.
Sent: Wednesday, September 16, 2015 11:36 AM
Hi Mark, Jani,
Thank you for your responses.
FYI my build directory structure has:
D:\EPICS
	Base
	Support
		Seq
		Asyn
I have configured RELEASE in these modules as:
	EPICS_BASE=\EPICS\base
I have also experimented with (explicitly) D:\EPICS\base - I prefer to avoid doing so, as the C: drive could be used.
I have also experimented with various combinations of the slash character.
None of this made any difference.
You are correct, perl -CSD \EPICS\base/bin/win32-x86-static/makeMakefile.pl ... is the correct and expected output.
I have no idea why D:/EPICS/support/asyn/configure/ has been prepended - it doesn't make any sense.
Also, why are the directories '.' and '..' being compiled as perl scripts, resulting in 'permission denied'?
BTW, I have not set any unusual permissions - (Everyone - Read only), (Administrators, system and myself, full control).
Cheers,
Peter.
Sent: 15 September 2015 21:43
To: 'Jani Hakala'; Heesterman, Peter J
Hi Peter,
I agree with Jani.
This is what you are getting:
make[1]: Entering directory `D:/EPICS/support/asyn/configure'
perl -CSD D:/EPICS/support/asyn/configure/\EPICS\base/bin/win32-x86-static/makeMakefile.pl O.win32-x86-static ../..
This is what I get:
make[1]: Entering directory 'C:/EPICS/Support-3-15/asyn-R4-26/configure'
perl -CSD C:/EPICS/base-3.15.2/bin/windows-x64/makeMakefile.pl O.windows-x64 ../..
For some reason for you it is putting the current path in front of the path to the makeMakefile.pl script in EPICS base.
How have you defined EPICS_BASE in asyn/configure/RELEASE?
From: [email protected] [mailto:[email protected]] On Behalf Of Jani Hakala
Sent: Tuesday, September 15, 2015 3:03 PM
Subject: Re: Unable to build support modules on Windows, with base 3.15.2
"Heesterman, Peter J" <[email protected]> writes:
> Hi,
> I just downloaded EPICS base 3.15.2, superseding previous 3.15.1.  I
> am experiencing a problem building any of the support modules, while
> using the make file build.  (There is no problem building base 3.15.2
> itself, however.)
> I've built all the same code successfully on Linux, while using
> 3.15.2.
> See attached, these are examples when trying to build Asyn or Seq, but
> this applies to all modules I've looked at, and to different build
> configurations I've attempted.  It all built OK when using 3.15.1.
> What could I be missing?
This doesn't look so good
i.e. that "\EPICS\base" part.
I would check the contents of asyn/configure/RELEASE for definitions of SUPPORT and EPICS_BASE or the contents of environment variables.
Jani Hakala
RE: Unable to build support modules on Windows, with base 3.15.2 Heesterman, Peter J
Re: Unable to build support modules on Windows, with base 3.15.2 Jani Hakala
RE: Unable to build support modules on Windows, with base 3.15.2 Mark Rivers
Prev: RE: Unable to build support modules on Windows, with base 3.15.2 Heesterman, Peter J
Next: RE: Unable to build support modules on Windows, with base 3.15.2 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Unable to build support modules on Windows, with base 3.15.2 Heesterman, Peter J
