Subject: |
RE: Unable to build support modules on Windows, with base 3.15.2 |
"Mark S. Engbretson" <[email protected]> |
To: |
Date: |
Wed, 16 Sep 2015 14:45:31 -0500 |
You know - this sort of issue happens all the time on windows builds for
EPICS, synapps, and area detector and I am always amazed that there isn't a
location where people have specifically stated the exact version of what and
where they obtained EVERYTHING, and that it is *known* to work.
I.e., I'm using this (hopefully) free version of a Microsoft compiler,
whatever specific perl or gnu utilities, got my sources from this location,
patched or kicked back versions of sources when people twiddle with them.
I've never understood the point of making everyone build everything from
first principles when the target your going for is always moving or isn't
all based upon the "official" stable distro's. I'd much rather have my
entire development environment be identical to everyone else's; so people
can focus their time and effort on doing <whatever>, not trying to figure
out why their stuff doesn't build.
-----Original Message-----
On Behalf Of Mark Rivers
Sent: Wednesday, September 16, 2015 1:35 PM
To: 'Bob Soliday' <[email protected]>; [email protected]
Subject: RE: Unable to build support modules on Windows, with base 3.15.2
I am running 4.1 as well.
On Behalf Of Bob Soliday
Sent: Wednesday, September 16, 2015 1:32 PM
To: [email protected]
Subject: Re: Unable to build support modules on Windows, with base 3.15.2
What version of gnumake are you using on Windows? When I use 3.81 I get
similar errors compiling my code in extensions. When I switch to 4.1 the
errors disappear.
On 09/16/2015 01:22 PM, Mark Rivers wrote:
> Do these files optionally included from asyn/configure/RELEASE exist and
contain anything?
> -include $(TOP)/../configure/SUPPORT.$(EPICS_HOST_ARCH)
> -include $(TOP)/../configure/EPICS_BASE.$(EPICS_HOST_ARCH)
> Where $(EPICS_HOST_ARCH) is probably win32-x86-static for the builds you
have been doing.
> Mark
> From: Heesterman, Peter J [mailto:[email protected]]
> Sent: Wednesday, September 16, 2015 1:19 PM
> To: Mark Rivers; 'Jani Hakala'
> Cc: EPICS Tech-Talk ([email protected])
> 3.15.2
> Hi Mark,
>>> modified any of the files in base/configure/os?
> No. I've checked carefully.
> The RELEASE file is attached (as been fiddling with D:'s and slashes).
> Which set are you referring to?
> Do you mean setting the path to perl, called from win32.bat?
> D:\EPICS>REM --------------- ActiveState perl -------------------
> D:\EPICS>set
> PATH=C:\Perl\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\SYSTEM32\Wb
> em
> Cheers,
> Peter.
> From: Mark Rivers [mailto:[email protected]]
> Sent: 16 September 2015 18:54
> To: Heesterman, Peter J; 'Jani Hakala'
> 3.15.2
> Strange, it is putting the current path in front of the path to the perl
script in base.
> Have you modified any of the files in base/configure/os?
> Send the contents of asyn/configure/RELEASE and the output of the "set"
command.
> Mark
> Sent: Wednesday, September 16, 2015 12:21 PM
> 3.15.2
> Hi Mark,
> That's a combination that I've tried, with the result attached.
> Cheers,
> Peter.
> Sent: 16 September 2015 17:45
> 3.15.2
> I define EPICS_BASE like this:
> EPICS_BASE=H:/epics/base-3.14.12.5
> I use a drive letter and forward slashes.
> Mark
> Sent: Wednesday, September 16, 2015 11:36 AM
> 3.15.2
> Hi Mark, Jani,
> Thank you for your responses.
> FYI my build directory structure has:
> D:\EPICS
> Base
> Support
> Seq
> Asyn
> I have configured RELEASE in these modules as:
> EPICS_BASE=\EPICS\base
> I have also experimented with (explicitly) D:\EPICS\base - I prefer to
avoid doing so, as the C: drive could be used.
> I have also experimented with various combinations of the slash character.
> None of this made any difference.
> You are correct, perl -CSD
\EPICS\base/bin/win32-x86-static/makeMakefile.pl ... is the correct and
expected output.
> I have no idea why D:/EPICS/support/asyn/configure/ has been prepended -
it doesn't make any sense.
> Also, why are the directories '.' and '..' being compiled as perl scripts,
resulting in 'permission denied'?
> BTW, I have not set any unusual permissions - (Everyone - Read only),
(Administrators, system and myself, full control).
> Cheers,
> Peter.
> Sent: 15 September 2015 21:43
> To: 'Jani Hakala'; Heesterman, Peter J
> 3.15.2
> Hi Peter,
> I agree with Jani.
> This is what you are getting:
> make[1]: Entering directory `D:/EPICS/support/asyn/configure'
> perl -CSD
D:/EPICS/support/asyn/configure/\EPICS\base/bin/win32-x86-static/makeMakefil
e.pl O.win32-x86-static ../..
> This is what I get:
> make[1]: Entering directory 'C:/EPICS/Support-3-15/asyn-R4-26/configure'
> perl -CSD C:/EPICS/base-3.15.2/bin/windows-x64/makeMakefile.pl
O.windows-x64 ../..
> For some reason for you it is putting the current path in front of the
path to the makeMakefile.pl script in EPICS base.
> How have you defined EPICS_BASE in asyn/configure/RELEASE?
> Mark
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Jani Hakala
> Sent: Tuesday, September 15, 2015 3:03 PM
> 3.15.2
> "Heesterman, Peter J" <[email protected]> writes:
>> Hi,
>> I just downloaded EPICS base 3.15.2, superseding previous 3.15.1. I
>> am experiencing a problem building any of the support modules, while
>> using the make file build. (There is no problem building base 3.15.2
>> itself, however.)
>> I've built all the same code successfully on Linux, while using
>> 3.15.2.
>> See attached, these are examples when trying to build Asyn or Seq,
>> but this applies to all modules I've looked at, and to different
>> build configurations I've attempted. It all built OK when using 3.15.1.
>> What could I be missing?
> This doesn't look so good
> perl -CSD
> i.e. that "\EPICS\base" part.
> I would check the contents of asyn/configure/RELEASE for definitions of
SUPPORT and EPICS_BASE or the contents of environment variables.
> Jani Hakala
- Re: Unable to build support modules on Windows, with base 3.15.2 J. Lewis Muir
- Unable to build support modules on Windows, with base 3.15.2 Heesterman, Peter J
- Re: Unable to build support modules on Windows, with base 3.15.2 Jani Hakala
- RE: Unable to build support modules on Windows, with base 3.15.2 Mark Rivers
- RE: Unable to build support modules on Windows, with base 3.15.2 Heesterman, Peter J
- Re: Unable to build support modules on Windows, with base 3.15.2 Bob Soliday
setpoint deadband on motor record Pearson, Matthew R.
<2015>
2025
2026
<2015>
2025
2026
