Hi Bob, Mark,
I was running gnumake 3.81 (which seems to be the most recent binary-installable version from http://gnuwin32.sourceforge.net/packages/make.htm?).
I downloaded make.exe (only) from http://www.equation.com/servlet/equation.cmd?fa=make and replaced (re-named) the existing make.exe.
(Don't think this is the 'proper' install process...?)
Now I'm able to build normally.
Many thanks,
Peter.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Bob Soliday
Sent: 16 September 2015 19:32
To: [email protected]
Subject: Re: Unable to build support modules on Windows, with base 3.15.2
What version of gnumake are you using on Windows? When I use 3.81 I get similar errors compiling my code in extensions. When I switch to 4.1 the errors disappear.
On 09/16/2015 01:22 PM, Mark Rivers wrote:
> Do these files optionally included from asyn/configure/RELEASE exist and contain anything?
> -include $(TOP)/../configure/SUPPORT.$(EPICS_HOST_ARCH)
> -include $(TOP)/../configure/EPICS_BASE.$(EPICS_HOST_ARCH)
> Where $(EPICS_HOST_ARCH) is probably win32-x86-static for the builds you have been doing.
> Mark
> From: Heesterman, Peter J [mailto:[email protected]]
> Sent: Wednesday, September 16, 2015 1:19 PM
> To: Mark Rivers; 'Jani Hakala'
> Cc: EPICS Tech-Talk ([email protected])
> Subject: RE: Unable to build support modules on Windows, with base
> 3.15.2
> Hi Mark,
>>> modified any of the files in base/configure/os?
> No. I've checked carefully.
> The RELEASE file is attached (as been fiddling with D:'s and slashes).
> Which set are you referring to?
> Do you mean setting the path to perl, called from win32.bat?
> D:\EPICS>REM --------------- ActiveState perl -------------------
> D:\EPICS>set
> PATH=C:\Perl\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\SYSTEM32\Wb
> em
> Cheers,
> Peter.
> From: Mark Rivers [mailto:[email protected]]
> Sent: 16 September 2015 18:54
> To: Heesterman, Peter J; 'Jani Hakala'
> 3.15.2
> Strange, it is putting the current path in front of the path to the perl script in base.
> Have you modified any of the files in base/configure/os?
> Send the contents of asyn/configure/RELEASE and the output of the "set" command.
> Mark
> Sent: Wednesday, September 16, 2015 12:21 PM
> 3.15.2
> Hi Mark,
> That's a combination that I've tried, with the result attached.
> Cheers,
> Peter.
> Sent: 16 September 2015 17:45
> 3.15.2
> I define EPICS_BASE like this:
> EPICS_BASE=H:/epics/base-3.14.12.5
> I use a drive letter and forward slashes.
> Mark
> Sent: Wednesday, September 16, 2015 11:36 AM
> 3.15.2
> Hi Mark, Jani,
> Thank you for your responses.
> FYI my build directory structure has:
> D:\EPICS
> Base
> Support
> Seq
> Asyn
> I have configured RELEASE in these modules as:
> EPICS_BASE=\EPICS\base
> I have also experimented with (explicitly) D:\EPICS\base - I prefer to avoid doing so, as the C: drive could be used.
> I have also experimented with various combinations of the slash character.
> None of this made any difference.
> You are correct, perl -CSD \EPICS\base/bin/win32-x86-static/makeMakefile.pl ... is the correct and expected output.
> I have no idea why D:/EPICS/support/asyn/configure/ has been prepended - it doesn't make any sense.
> Also, why are the directories '.' and '..' being compiled as perl scripts, resulting in 'permission denied'?
> BTW, I have not set any unusual permissions - (Everyone - Read only), (Administrators, system and myself, full control).
> Cheers,
> Peter.
> Sent: 15 September 2015 21:43
> To: 'Jani Hakala'; Heesterman, Peter J
> 3.15.2
> Hi Peter,
> I agree with Jani.
> This is what you are getting:
> make[1]: Entering directory `D:/EPICS/support/asyn/configure'
> perl -CSD D:/EPICS/support/asyn/configure/\EPICS\base/bin/win32-x86-static/makeMakefile.pl O.win32-x86-static ../..
> This is what I get:
> make[1]: Entering directory 'C:/EPICS/Support-3-15/asyn-R4-26/configure'
> perl -CSD C:/EPICS/base-3.15.2/bin/windows-x64/makeMakefile.pl O.windows-x64 ../..
> For some reason for you it is putting the current path in front of the path to the makeMakefile.pl script in EPICS base.
> How have you defined EPICS_BASE in asyn/configure/RELEASE?
> Mark
> [mailto:[email protected]] On Behalf Of Jani Hakala
> Sent: Tuesday, September 15, 2015 3:03 PM
> 3.15.2
> "Heesterman, Peter J" <[email protected]> writes:
>> Hi,
>> I just downloaded EPICS base 3.15.2, superseding previous 3.15.1. I
>> am experiencing a problem building any of the support modules, while
>> using the make file build. (There is no problem building base 3.15.2
>> itself, however.)
>> I've built all the same code successfully on Linux, while using
>> 3.15.2.
>> See attached, these are examples when trying to build Asyn or Seq,
>> but this applies to all modules I've looked at, and to different
>> build configurations I've attempted. It all built OK when using 3.15.1.
>> What could I be missing?
> This doesn't look so good
> i.e. that "\EPICS\base" part.
> I would check the contents of asyn/configure/RELEASE for definitions of SUPPORT and EPICS_BASE or the contents of environment variables.
> Jani Hakala
- RE: Unable to build support modules on Windows, with base 3.15.2 Mark Rivers
- Unable to build support modules on Windows, with base 3.15.2 Heesterman, Peter J
- Re: Unable to build support modules on Windows, with base 3.15.2 Jani Hakala
- RE: Unable to build support modules on Windows, with base 3.15.2 Heesterman, Peter J
- Re: Unable to build support modules on Windows, with base 3.15.2 Bob Soliday
Agilent DSO-X 2014A Lionberger, Carl A.
"security audit" of EPICS / Channel Access? Hartman, Steven M.
<2015>
2025
2026
<2015>
2025
2026
