1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Serial port COM10: not work?
To: Jack <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 30 Sep 2015 12:24:28 +0000
That may depend on which version of asyn you are using.  The upcoming R4-27 release contains the following in the release notes:
Fix to automatically prefix COM port names larger than COM9 (e.g. COM10, COM11, etc.) with "\.\". This is needed for all ports except COM1-COM9. Thanks to Freddie      Akeroyd for this fix.
If you are running the master branch from github you already have this fix.  If not then I think you can work around the problem by using the full path name to the port when you open it, i.e. \\.\COM10.
From: [email protected] [[email protected]] on behalf of Jack [[email protected]]
Sent: Wednesday, September 30, 2015 4:50 AM
To: [email protected]
Subject: Re: Serial port COM10: not work?
Hi Peter,
I'm using asyn/stream with ports 10 and 11 without troubles.
HTH,
-Mauro
On 9/29/2015 8:04 PM, Heesterman, Peter J wrote:
@font-face
	{font-family:"MS Mincho"}
@font-face
@font-face
	{font-family:Calibri}
p.MsoNormal, li.MsoNormal, div.MsoNormal
	{margin:0cm;
	margin-bottom:.0001pt;
	font-size:11.0pt;
	font-family:"Calibri","sans-serif"}
a:link, span.MsoHyperlink
	{color:blue;
	text-decoration:underline}
a:visited, span.MsoHyperlinkFollowed
	{color:purple;
span.EmailStyle17
	{font-family:"Calibri","sans-serif";
	color:windowtext}
.MsoChpDefault
	{font-family:"Calibri","sans-serif"}
@page WordSection1
	{margin:72.0pt 72.0pt 72.0pt 72.0pt}
The devices (pump controllers) are named TT01, TT02, TT03, TT04, NT07 and NT10, respectively.
These were attached to COM1, COM2, COM3, COM4, COM7 and COM10 (only in the interests of matching the number scheme, above).
When I installed the software, the first five worked perfectly.
But the last one was unable to connect.
On a hunch, we re-mapped the last comport to COM8:, in the operating system.
Now all 6 work perfectly.
I wondered if there is a single-numeric-digit constraint, on the serial port number?
Peter.
________________________________________________________________________
Mauro Giacchini
Controls System Specialist
Istituto Nazionale di Fisica Nucleare - Laboratori Nazionali di Legnaro
V.le dell'Universita', 2
35020 LEGNARO (PD) - ITALY
Phone: +39.049.8068558
EPICS _at_ LNL http://www.lnl.infn.it/~epics/
...the first EPICS installation to the project SPES realized from the
scratch in ITALY is in production since begin 2010!!
This email has been checked for viruses by Avast antivirus software.
www.avast.com
Re: Serial port COM10: not work? Eric Norum
RE: Serial port COM10: not work? Heesterman, Peter J
Re: Serial port COM10: not work? Jack
Prev: Re: Serial port COM10: not work? Jack
Next: New sequencer releases Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Serial port COM10: not work? Eric Norum
