1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Serial port COM10: not work?
Cc: "EPICS Tech-Talk \([email protected]\)" <[email protected]>
Date: Wed, 30 Sep 2015 09:14:14 -0700
I’m not convinced that burying windows-specific code like that into the configure command is a good idea.
What’s so hard about just noting in the documentation that COM ports above 9 require special naming — and since the IOC shell treats backslashes separately:
drvAsynSerialPortConfigure(“L10”, “\\\\.\\COM10”, ……..)
On Sep 30, 2015, at 5:24 AM, Mark Rivers <[email protected]> wrote:
That may depend on which version of asyn you are using.  The upcoming R4-27 release contains the following in the release notes:
Fix to automatically prefix COM port names larger than COM9 (e.g. COM10, COM11, etc.) with "\.\". This is needed for all ports except COM1-COM9. Thanks to Freddie      Akeroyd for this fix.
If you are running the master branch from github you already have this fix.  If not then I think you can work around the problem by using the full path name to the port when you open it, i.e. \\.\COM10.
Eric Norum
[email protected]
RE: Serial port COM10: not work? Mark Rivers
Serial port COM10: not work? Heesterman, Peter J
Re: Serial port COM10: not work? Jack
Prev: sumo - builder of consistent sets of EPICS support modules, now with svn and cvs support Goetz Pfeiffer
Next: RE: Serial port COM10: not work? Heesterman, Peter J
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Serial port COM10: not work? Mark Rivers
Next: RE: Serial port COM10: not work? Mark Rivers
