> — and since the IOC shell treats backslashes separately:
> drvAsynSerialPortConfigure(“L10”, “\\\\.\\COM10”, ……..)
I just determined that your example above is not what the iocsh does. If the string is inside quotes the iocsh does not treat backslashes separately, but without the quotes it does:
drvAsynSerialPortConfigure("L0",\\\\.\\COM1,0,0,0)
drvAsynSerialPortConfigure("L0","\\.\COM1",0,0,0)
Both of the above pass \\.\COM1 to the driver.
drvAsynSerialPortConfigure("L0","\\\\.\\COM1",0,0,0)
passes \\\\.\\COM1 to the driver.
Sent: Wednesday, September 30, 2015 11:14 AM
To: Mark Rivers
Cc: EPICS Tech-Talk ([email protected])
Subject: Re: Serial port COM10: not work?
I’m not convinced that burying windows-specific code like that into the configure command is a good idea.
What’s so hard about just noting in the documentation that COM ports above 9 require special naming — and since the IOC shell treats backslashes separately:
On Sep 30, 2015, at 5:24 AM, Mark Rivers <[email protected]<mailto:[email protected]>> wrote:
That may depend on which version of asyn you are using. The upcoming R4-27 release contains the following in the release notes:
Fix to automatically prefix COM port names larger than COM9 (e.g. COM10, COM11, etc.) with "\.\". This is needed for all ports except COM1-COM9. Thanks to Freddie Akeroyd for this fix.
If you are running the master branch from github you already have this fix. If not then I think you can work around the problem by using the full path name to the port when you open it, i.e. \\.\COM10<UrlBlockedError.aspx>.
Eric Norum
- Serial port COM10: not work? Heesterman, Peter J
- Re: Serial port COM10: not work? Jack
- RE: Serial port COM10: not work? Mark Rivers
- Re: Serial port COM10: not work? Eric Norum
RE: EPICS Collaboration Meeting Andrew C. Starritt
<2015>
2025
2026
RE: Serial port COM10: not work? Heesterman, Peter J
<2015>
2025
2026
