I don't think we should do this. What is the serial port is on a USB to serial converter? On Linux this might be /dev/ttyUSB0, so do we also translate that? I think it's better to use the native OS device names.
Sent: Thursday, October 01, 2015 6:15 AM
To: Mark Rivers; 'Eric Norum'
Cc: EPICS Tech-Talk ([email protected])
Subject: RE: Serial port COM10: not work?
Hi Mark,
Just a separate suggestion, while we’re on the subject of Windows serial port naming.
I wondered if it might be appropriate to provide ‘translation’ from /dev/ttyS<n> to \\.\COM<n+1>, in order to hide the operating system dependency?
Peter.
From: [email protected] [mailto:[email protected]] On Behalf Of Mark Rivers
Sent: 30 September 2015 18:31
To: 'Eric Norum'
The code in question is in the Windows-specific driver file (drvAsynSerialPortWin32.c), so it is already Windows-specific. We are not adding OS-specific code to a generic driver.
I don’t like users having to put 6 backslash characters into the device name, where everywhere else in Windows they just say COM10.
I agree with Peter’s suggestion that we don’t need a special case for COM1-COM9.
I propose the following:
- If the device name passed to drvAsynSerialPortConfigure starts with ‘\’ then assume the user has used a device name, and use it directly.
- If the device name does not begin with ‘\’ then prepend “\\.\<UrlBlockedError.aspx>”.
Sent: Wednesday, September 30, 2015 11:14 AM
To: Mark Rivers
Cc: EPICS Tech-Talk ([email protected]<mailto:[email protected]>)
Subject: Re: Serial port COM10: not work?
I’m not convinced that burying windows-specific code like that into the configure command is a good idea.
What’s so hard about just noting in the documentation that COM ports above 9 require special naming — and since the IOC shell treats backslashes separately:
drvAsynSerialPortConfigure(“L10”, “\\\\.\\COM10<file:///\\COM10>”, ……..)
On Sep 30, 2015, at 5:24 AM, Mark Rivers <[email protected]<mailto:[email protected]>> wrote:
That may depend on which version of asyn you are using. The upcoming R4-27 release contains the following in the release notes:
Fix to automatically prefix COM port names larger than COM9 (e.g. COM10, COM11, etc.) with "\.\". This is needed for all ports except COM1-COM9. Thanks to Freddie Akeroyd for this fix.
If you are running the master branch from github you already have this fix. If not then I think you can work around the problem by using the full path name to the port when you open it, i.e. \\.\COM10<UrlBlockedError.aspx>.
Eric Norum
- Serial port COM10: not work? Heesterman, Peter J
- Re: Serial port COM10: not work? Jack
- RE: Serial port COM10: not work? Mark Rivers
- Re: Serial port COM10: not work? Eric Norum
- RE: Serial port COM10: not work? Heesterman, Peter J
RE: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 freddie.akeroyd
<2015>
2025
2026
<2015>
2025
2026
