1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2
To: Ben Franksen <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 2 Oct 2015 22:07:05 +0000
Thanks Ben
I saw a note from Kevin Peterson that I should be using VS 2010 and not VS2015 because several other synApps modules will  not build... I had been using VS2008 forever, but it lacks modern C++ etc. VS2010 lacks modern C++ for that matter as well...
I can't get it to build with VS2015 so I am trying VS2010. It is now harder to find on the internet, and comes as a *.iso, which needs a special tool do even mount it on windows 7. So many wrinkles.
Thanks for the response. Have a good weekend.
T
Sent: Friday, October 02, 2015 4:55 PM
To: Madden, Timothy J.; [email protected]
Subject: Re: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2
Am 02.10.2015 um 23:20 schrieb Madden, Timothy J.:
> Dear EPICS:
> Trying to build seq 2.2.3 with epics base 3.15.2. I am using the windows
> 2015 compiler on a 64 bit machine.
> I am building in 64 bit mode.
> I saw some tech talk notes that this does not work?
The latest release 2.2.3 should build correctly on Windows. You can even
run the test suite. Mark even attested that this is the case on
tech-talk. The comment you refer to was written before 2.2.3 was released.
> Mark R. says one can make this work with 2.2.x snapshot etc. etc. I
> don't know where to get this. it is not on the seq web site.
It is:
http://www-csr.bessy.de/control/SoftDist/sequencer/Installation.html#download
contains a link to the latest snapshot
(http://www-csr.bessy.de/control/SoftDist/sequencer/releases/seq-2-2-snapshot-latest.tar.gz).
However, you no longer need to use a snapshot.
Cheers
Ben
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 Ben Franksen
Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 Madden, Timothy J.
Prev: Re: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 Ben Franksen
Next: RE: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 Madden, Timothy J.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 Ben Franksen
