1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2
To: "Rivers, Mark L." <[email protected]>
Date: Fri, 2 Oct 2015 22:15:20 +0000
Thanks for the reply.
Here is the error message. I saw someone else had gotten a similar message. With other epics base it goes away, but the 2015 compiler does not work with older EPICS.
Tim
See below-----------------------------------------------
D:\EPICS\ADEpics\synApps_5_5\support\seq-2.2.3>make
cygwin warning:
  MS-DOS style path detected: D:/EPICS/ADEpics/base-3.15.2/configure/CONFIG
  Preferred POSIX equivalent is: /cygdrive/d/EPICS/ADEpics/base-3.15.2/configure
/CONFIG
  CYGWIN environment variable option "nodosfilewarning" turns off this warning.
  Consult the user's guide for more details about POSIX paths:
    http://cygwin.com/cygwin-ug-net/using.html#using-pathnames
make -C ./configure install
make[1]: Entering directory `/cygdrive/d/EPICS/ADEpics/synApps_5_5/support/seq-2
.2.3/configure'
perl -CSD /cygdrive/d/EPICS/ADEpics/synApps_5_5/support/seq-2.2.3/configure/D:/E
PICS/ADEpics/base-3.15.2/bin/windows-x64-debug/makeMakefile.pl O.windows-x64-deb
ug ../..
Can't open perl script "/cygdrive/d/EPICS/ADEpics/synApps_5_5/support/seq-2.2.3/
configure/D:/EPICS/ADEpics/base-3.15.2/bin/windows-x64-debug/makeMakefile.pl": N
o such file or directory
make[1]: *** [O.windows-x64-debug] Error 2
make[1]: Leaving directory `/cygdrive/d/EPICS/ADEpics/synApps_5_5/support/seq-2.
2.3/configure'
make: *** [configure.install] Error 2
-----------------------------------------------END------------------------------------------------
Sent: Friday, October 02, 2015 4:50 PM
To: Madden, Timothy J.
Cc: [email protected]
Subject: Re: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2
2.2.3 does work for me with VS 2010 and 3.14.12.5. It was 2.2.2 that did not work. I have not tested your combination of compiler and base, but please send the error message.
Sent from my iPhone
On Oct 2, 2015, at 4:20 PM, Madden, Timothy J. <[email protected]<mailto:[email protected]>> wrote:
Dear EPICS:
Trying to build seq 2.2.3 with epics base 3.15.2. I am using the windows 2015 compiler on a 64 bit machine.
I am building in 64 bit mode.
I saw some tech talk notes that this does not work?
Mark R. says one can make this work with 2.2.x snapshot etc. etc. I don't know where to get this. it is not on the seq web site.
Thanks
Tim Madden
APS
Re: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 Mark Rivers
Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 Madden, Timothy J.
Prev: RE: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 Madden, Timothy J.
Next: Re: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 Ben Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 Mark Rivers
Next: Re: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 Mark Rivers
